Updated on 2026-09-18 GMT+08:00
Line Chart
A line chart is used to analyze the data change trend in a certain period, which is reflected in the following aspects:
  • Increment or decrement
  • Increase/Decrease rate
  • Regularity of increase/decrease (such as periodic change)
  • Peak and valley values
Therefore, the line chart is the best choice for analyzing the data change trend over time. In addition, you can draw multiple lines to analyze the change trend of multiple groups of data in the same period, and then analyze the interaction and impact between data (such as in direct or inverse proportion).
Checking Line Charts
  1. Log in to the LTS console.
  2. On the Log Management page, select the target log group and log stream. The log stream details page is displayed.
  3. Click the Charts tab.
    The old log analysis function is going offline. You are advised to use the new SQL engine on the Charts tab page to configure charts. This new engine is more powerful, allowing you to use the pipe character (|) to combine search and analysis statements.
  4. Enter a query and analysis statement, set a time range, and click Search. For detailed syntax, see SQL Functions.
  5. Click to display the queried data in a line chart. In the configuration area on the right, set parameters by referring to Table 1.
    Figure 1 Line chart
    Table 1 Line chart parameters
    Type
    Standard
    Format
    Select K,Mil,Bil, 1,000,000, or Byte,KB,MB from the drop-down list to specify the format of the Y axis.
    Unit
    Customize the unit of the Y axis.
    Decimal Places
    Sets the number of decimal places to be displayed.
    Title Font Size
    Sets the font size of the chart title.
    Query/Analysis
    X Axis
    Numeric or string data is supported.
    Y Axis
    Numeric or string data is supported. You can select multiple data records.
    Dimension
    Select a value from the drop-down list. Generally, it is an ordinal variable.
    Compare Trends
    This function can be enabled when the X axis shows time data and Dimension is not specified.
    After this function is enabled, set Comparison to a duration less than or equal to 24 hours. After the setting is complete, compare the data of the current time with the object time data.
    Legend
    Hide Legend
    After this function is enabled, you can hide the legend and comparison results.
    Legend Position
    Select Top or Right.
    Comparison Value
    Indicates whether to display the maximum value, minimum value, average value, and sum value. You can select multiple options.
    Graphics
    Line Shape
    Line type. Select Straight or Curved.
    Line Width
    Width of a polyline.
    Show Data Markers
    Whether to display the connection points.
    Top Margin
    Specifies the distance between the axis and the upper boundary of the graph.
    Bottom Margin
    Specifies the distance between the axis and the lower boundary of the graph.
    Left Margin
    Specifies the distance between the axis and the left boundary of the graph.
    Right Margin
    Specifies the distance between the axis and the right boundary of the graph.
    Tooltip
    Sort By
    Dialog box configuration. When multiple Y-axis data records are selected, they can be sorted and displayed.
    X Axis
    Show
    After this function is enabled, data on the X axis is displayed.
    X Axis Title
    Title of the X axis.
    Y Axis
    Show
    After this function is enabled, the Y axis data is displayed.
    Y Axis Title
    Title of the Y axis.
    Position
    Position of the Y axis. Select Left or Right.
