Transferring Logs to DIS
- You are advised to transfer logs to DMS.
- This function is available only in regions CN North-Beijing4, CN North-Beijing1, CN East-Shanghai2, CN South-Guangzhou, CN-Hong Kong, and AP-Singapore. To use it in other regions, you need to submit a service ticket to DIS. For details, see Submitting a Service Ticket.
Billing
LTS charges you based on the actual volume of logs transferred. For details, see LTS Pricing Details. In addition, you will be billed for your DIS storage usage. For details, see DIS Pricing Details.
- Logs have been ingested to LTS. For details, see Log Ingestion.
- DIS has been enabled. For details, see Creating a DIS Stream.
- Currently, this function is available only in regions CN North-Beijing4, CN North-Beijing1, CN East-Shanghai2, CN South-Guangzhou, CN-Hong Kong, and AP-Singapore. To use it in other regions, you need to submit a service ticket to DIS. For details, see Submitting a Service Ticket.
- Log in to the LTS console.
- In the navigation pane, choose Log Transfer.
- Click Configure Log Transfer in the upper right corner.
- On the displayed page, configure the log transfer parameters.
Table 1 Transfer parameters Parameter
Example Value
Source Account
- Current: Logs of the current account will be transferred.
- Other: Logs of the delegator account will be transferred. Ensure that the delegator has created an agency for log transfer delegation. For details, see Creating an Agency. Note down the names of the created agency and the delegator account.
Current
Agency Name
This parameter is required when Log Source Account is set to Other. Enter the name of the IAM agency created by the delegator.
Delegator Account Name
This parameter is required when Log Source Account is set to Other. Enter the account name of the delegator.
Enable Transfer
Whether log transfer is enabled.
Enabled
Transfer Destination
Select a cloud service to which logs are transferred.
DIS
Log Group Name
Select a log group.
Log Stream Name
Select a log stream. Log streams that have been configured with DIS transfer settings cannot be configured again.
DIS Stream Name
Select a DIS stream. If no streams are available, click View DIS Streams to access the DIS console and create a stream.
Format
The storage format of logs. The value can be Raw log format or JSON.
- Example of the raw log format:
- Example of the JSON format:
{"host_name":"ecs-bd70","ip":"192.168.0.54","line_no":249,"message":"Sep 30 14:40:01 ecs-bd70 CRON[4363]: (root) CMD (/opt/oss/servicemgr/ICAgent/bin/manual/mstart.sh > /dev/null 2>&1)\n","path":"/var/log/syslog","time":1569825602303}
JSON
Transfer Interval
Logs are transferred to the DIS stream in real time.
Real time
Filter by Tag Fields
During transfer, logs will be filtered by tag fields collected by ICAgent.
- Disabled: Logs will not be filtered by tag fields.
- Enabled: The default tag fields include those for hosts (hostIP, hostId, hostName, pathFile, and collectTime) and for Kubernetes (clusterName, clusterId, nameSpace, podName, containerName, and appName). Optional public tag fields are regionName, logStreamName, logGroupName, and projectId. When Filter by Tag Fields is enabled, Format must be JSON.
- Transfer Tag: After this function is enabled, log stream tags are also transferred.
Enabled
- Click OK. When the log transfer status changes to Normal, the transfer task has been created.
- Click the DIS stream name in the Transfer Destination column to access the DIS console and view transferred log files.
Transferred logs can be downloaded from DIS to your local PC for viewing.
Deleting a transfer task will stop log transfer, and the deleted task cannot be restored. Exercise caution when performing this operation.
- After a transfer task is deleted, the logs that have been transferred remain in DIS.
- To delete the transfer task, log in to the DIS console, choose Stream Management, and select the DIS instance to go to the instance details page. Delete the upload permission under Permissions.
- Delete a single transfer task:
- Click Delete in the Operation column of the target task.
- Delete transfer tasks in batches:
- Select the transfer tasks to be deleted and click Delete above the list.
Helpful Links
- If you have any questions when configuring log transfer, see Log Transfer in the FAQ.
- You can create, query, and delete log transfer tasks by calling APIs. For details, see Log Transfer.
