Creating a LakeFormation Access Client
On the access management page, you can create and manage clients, view client IP addresses, and use the IP addresses to connect multiple services to LakeFormation instances.
- Log in to the LakeFormation console.
- Select the LakeFormation instance to be operated from the drop-down list on the left and click Clients in the navigation pane.
- Click Create. In the displayed dialog box, set the following parameters and click OK.
If no suitable VPC or subnet is available, click create one to access the VPC console to create one.
Table 1 Parameters for creating an access management client Parameter
Client
Enter a client name.
VPC
VPC where the service to be connected is located.
Subnet
Subnet where the service to be connected is located.
- Click View Details in the Operation column to open the details page.
On the details page, you can view the ID, client name, status, access mode, VPC, subnet, endpoint ID, and access IP address.
- Interconnect other cloud services with LakeFormation based on the obtained information, such as the access IP address.
For details, see the operation guide for interconnecting the corresponding cloud service with LakeFormation. For how to interconnect LakeFormation with MRS, see Configuring a LakeFormation Data Connection.
