- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
- Developer Guide
API Reference
- Before You Start
- API Overview
- API Calling
API
Console
- Instance Management
- Job Management
Service Authorization Management
- Granting Permissions for Accessing Other Cloud Services
- Querying Cloud Service Access Permissions
- Registering a Tenant Agreement
- Querying whether a Tenant Has Registered an Agreement
- Deleting a Tenant Agreement
- Querying the Current System Agreement
- OBS Management
- Access Management
- Specification Management
- Quota Management Service
- Tag Management Service
- Agency Management
- Alarm Management
- Metadata Management
- Location
LakeCat
- Function Management
- Catalog Management
- Database Management
- Table Management
- Data Table Statistics
- Zone-based Management
- Partition Statistics
- Authorization Management
- User Group Management
- Metadata Statistics
Role Management
- Creating a Role
- Listing Roles on Different Pages by Condition
- Deleting a Role
- Obtaining a Role
- Modifying a Role
- Listing All Role Names
- Querying the Users or User groups Under a Role
- Adding One or More Users or User Groups to a Role
- Removing One or More Users or User Groups from a Role
- Updating the Entities in a Role
- Credential Management
- Configuration Management
- User
Console
- Application Examples
- Appendix
- FAQs
Show all
Configuring Cloud Service Authorization
Before using LakeFormation, you need to authorize it to access related cloud services.
- Log in to the management console as the user created in Registering a Huawei Cloud Account.
- Click the service list and choose Analytics > LakeFormation. On the displayed page, click Service Authorization the left navigation pane.
- IAM ReadOnlyAccess: allows your instance to obtain user group and user information when running.
- OBS OperateAccess: provides the storage function for your instance.
- OBS AccessLabel: allows your instance to control permissions by using tagging.
- OBS Bucket Lifecycle: This permission is required to manage the lifecycle of instances.
- VPCEndpoint Administrator: allows you to operate on VPC endpoint for instance access management.
- DNS FullAccess: allows you to modify DNS private domain names for instance access management.
- Select "I have read and agree with the LakeFormation Service Statement." Click Authorize.
After cloud service authorization, LakeFormation will create an agency named lakeformation_admin_trust in Identity and Access Management (IAM). Do not delete the agency when using LakeFormation.
If the agency fails to be automatically created, log in to the IAM console, delete the agency or contact the administrator to increase the quota, and check whether the current user has the permission to create an agency.
