- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
- Developer Guide
API Reference
- Before You Start
- API Overview
- API Calling
API
Console
- Instance Management
- Job Management
Service Authorization Management
- Granting Permissions for Accessing Other Cloud Services
- Querying Cloud Service Access Permissions
- Registering a Tenant Agreement
- Querying whether a Tenant Has Registered an Agreement
- Deleting a Tenant Agreement
- Querying the Current System Agreement
- OBS Management
- Access Management
- Specification Management
- Quota Management Service
- Tag Management Service
- Agency Management
- Alarm Management
- Metadata Management
- Location
LakeCat
- Function Management
- Catalog Management
- Database Management
- Table Management
- Data Table Statistics
- Zone-based Management
- Partition Statistics
- Authorization Management
- User Group Management
- Metadata Statistics
Role Management
- Creating a Role
- Listing Roles on Different Pages by Condition
- Deleting a Role
- Obtaining a Role
- Modifying a Role
- Listing All Role Names
- Querying the Users or User groups Under a Role
- Adding One or More Users or User Groups to a Role
- Removing One or More Users or User Groups from a Role
- Updating the Entities in a Role
- Credential Management
- Configuration Management
- User
Console
- Application Examples
- Appendix
- FAQs
Show all
Data Permission Overview
Data lake permissions can be configured in three dimensions: database, table, and function.
Cloud service administrators can configure permissions of different user groups for different managed objects to centrally manage data lake resources.
You can centrally manage permissions on resources in the data lake on the LakeFormation console. IAM users and user groups can also be associated with fine-grained permission policies of LakeFormation for authorization. For details, see Creating a Custom Policy. If there are a large number of data resources in the data lake, you are advised to use the LakeFormation console to centrally manage permissions on resources in the data lake.
The following table lists the main elements in LakeFormation permission configuration.
Element |
Description |
Authorization Entity |
You can specify any user group, role, IAM user, or agency to be the authorization entity. The name of an authorization entity cannot contain hyphens (-). Otherwise, the operation may fail. |
Granted To |
Operation Type |
Access permission on the authorization object that the authorization entity has. Different authorization objects support different operations. For details, see Table 2. |
Grant Authorization Permission |
Whether to grant the authorization permission. After the authorization permission is granted, the authorization entity can grant the permission to other authorization entities. |
Object |
Operation Type |
Description |
Catalog |
ALL |
Perform all operations on catalogs. |
ALTER |
Modify catalogs. |
CREATE_DATABASE |
Create databases. |
DROP |
Delete catalogs. |
DESCRIBE |
Check the metadata of catalogs or switch catalogs. |
LIST_DATABASE |
View the resource list in a catalog. |
Database |
ALL |
Perform all operations on databases. |
ALTER |
Modify databases. |
DROP |
Delete databases. |
DESCRIBE |
Check the metadata of databases or switch databases. |
LIST_TABLE |
View the resource list in a database. |
LIST_FUNC |
View functions in a database. |
CREATE_TABLE |
Create a table in a database. |
CREATE_FUNC |
Create a function in a database. |
Table |
ALL |
Perform all operations on tables. |
ALTER |
Modify tables. |
DROP |
Delete tables. |
DESCRIBE |
Check the metadata of tables. |
UPDATE |
Update table data. |
INSERT |
Insert table data. |
SELECT |
Query data in a table. |
DELETE |
Delete data from a table. |
Column |
SELECT |
Query column data in a table. |
Function |
ALL |
Perform all operations on functions. |
ALTER |
Modify functions. |
DROP |
Delete functions. |
DESCRIBE |
Check the metadata of functions. |
EXEC |
Execute functions. |
Path |
READ |
Read files stored in a path. |
WRITE |
Write data into the files stored in a path. |
Permission administrators are categorized into two types: system permission administrators and service permission administrators, each with distinct IAM permission requirements and scopes of permission management.
- System permission administrator
- System permission administrators need the following IAM operation permissions: lakeformation:policy:describe, lakeformation:policy:create, and lakeformation:policy:drop.
- System permission administrators can assign metadata permissions to other authorization entities and revoke the assigned permissions as well.
- Service permission administrator
- Service permission administrators need the following IAM operation permissions: lakeformation:policy:describe and lakeformation:policy:delegate.
- Service permission administrators are authorized to assign and revoke metadata permissions only after they have received the requisite permissions from the service permission administrator.
Assume that there are system permission administrator (User A), service permission administrator (User B), and common user (User C). After User A has granted User B the ALL permissions for Catalog1, along with authorization rights, User B is then able to grant permissions such as DESC for Catalog1 to User C. However, User B does not have the authority to grant permissions for any other catalogs to User C.
