Checking Monitoring Metrics
You will check KVS monitoring metrics on the Cloud Eye console.
At least one request for KVS has been reported (about 10 minutes) to Cloud Eye after a new store was created.
If there are no KVS requests reported for about two hours, the Cloud Eye console does not show any monitoring data. The data will be shown again about 10 minutes after a new KVS request is reported.
- Log in to the console.
- In the service list, under Management & Governance, click Cloud Eye.
- In the navigation pane, choose Cloud Service Monitoring > Key-Value Storage Service KVS.
- Find the required resource and click View Metric in the Operation column.
You can view metric data from the last 1, 3, 12, or 24 hours, as well as the last 7 days.
