Updated on 2025-03-07 GMT+08:00
Individual Space
The individual space stores your individual files and is visible only to you. If your administrator has allocated the individual space to you and the space is enabled, the individual space page is displayed.
The individual space page consists of two parts: operations and the list/card view of files/folders. If an administrator has transferred resources of users to a recipient, the recipient can view the transferred folders in the individual space.
Figure 1 File/Folder list in the individual space
Operations related to files/folders
  • Buttons: such as uploading, creating, downloading, moving, copying, and deleting files/folders.
  • Selected Files: displays the number of all or selected files/folders in the current list/card view in gray.
  • : You can search for files/folders in the individual space by name. Fuzzy search is supported.
  • : You can select the type of files/folders to be displayed in the list/card view.
  • : You can click it to display files/folders in the individual space in a list.
  • : You can click it to display files/folders in the individual space in cards.
List/Card view
  • The list view displays the file/folder name, size, format, and update time. You can sort files/folders in ascending or descending order by name, size, format, or update time. By default, files/folders are sorted by update time in descending order. Folders are always on the top. A thumbnail is displayed in the name column of an image file. You can click the thumbnail to check the original image.
  • The card view displays the file/folder name, update time, and format icon. By default, files/folders are sorted by update time in descending order. Folders are always on the top. A thumbnail is displayed in the card of an image file. You can click the thumbnail to check the original image.
