Viewing a Shared File/Folder
You can view and manage files shared by yourself and others.
Viewing a Shared File/Folder in KooDrive
- Sign in to the KooDrive service plane. Only a HUAWEI ID can be used to log in to the KooDrive service plane.
To log in as a common user, use the managed HUAWEI ID applied by the administrator for you on the console.
- In the navigation pane, choose Shared. On the Shared with Me tab, view the list of files/folders shared by others. On the Shared by Me tab, view the list of files/folders you share with others.
- The file/folder list on the Shared with Me tab displays the file/folder name, size, format, sharing status, sharing time, and sharer. You can download the files/folders, save them to KooDrive, view the sharing details, and clear the sharing records. For details, see More Operations.
- The file/folder list on the Shared by Me tab displays the file/folder name, sharing scope, access times, space, sharing status, and sharing time. You can copy the sharing link, view the sharing details, modify the sharing settings, copy the sharing link and password, and cancel the sharing. For details, see More Operations.
- The sharing status is as follows:
- File deleted: All files related to a sharing record do not exist (logically or physically deleted).
- Invalid: The space where the shared file/folder is located is disabled or you do not have the permissions to access the space.
- Expires in X days: The sharing will expire in X days. This countdown is displayed in the last seven days. If the sharing will expire in one day, Expires in X hours will be displayed.
- Specific expiration date: displayed when the sharer customizes a date seven days or more in the future. Expires in X days will be displayed when the sharing will expire in seven days or less.
- Expired: The sharing has expired.
Viewing a Shared File/Folder Through the Sharing URL
- Click the received sharing URL.
- If a password is required, enter the password and click Access File. The list of shared files/folders is displayed.
Check the sharer, sharing time, sharing validity period, and shared files/folders. You can also download files/folders and save them to KooDrive. For details, see More Operations.
Figure 1 Viewing shared files/folders through the sharing URLNOTE:
- If the shared URL has expired, you cannot access the shared files/folders. You can contact the sharer to obtain a valid URL.
- You can click Access KooDrive to access the service plane of the KooDrive user center.
More Operations
You can perform more operations on shared files/folders by referring to Table 1.
Role |
Operation |
Procedure |
Sharer |
Copying the sharing URL |
Viewing sharing details |
Modifying sharing settings |
Copying a sharing URL and password |
Canceling sharing |
Recipient |
Downloading a shared file/folder to the local device |
Saving a shared file/folder to KooDrive |
Clearing a sharing record |
