- Billing
- Getting Started
User Guide
- Before You Start
- Permissions Management
- Enabling KooDrive
- Creating an Organization and Configuring KooDrive
- KooDrive Services
- Auditing
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Department Management
- User Management
Space Management
- Listing Departments Spaces
- Querying Space Information
- Creating a Space for a Department or Individual
- Modifying Space Information
- Deleting a Space
- Querying Space Details by Space ID
- Querying Information About a Team Space
- Creating a Group Space
- Dismissing a Team Space
- Listing Group Spaces in an Enterprise
- Listing User Spaces
- Obtains space information.
- Group Management
- Session Management
- Service Subscription
- Enterprise Settings
- Other APIs
Permissions Templates
- Creating a Permissions Template
- Editing a Permissions Template
- Modifying the Status of Permissions Templates
- Deleting Permissions Templates in Batches
- Querying Permissions Template Details Based on the Permissions Template ID Array
- Listing Permissions Templates by Condition
- Adding or Modifying the Association Relationship of the Initial Member Permissions
- Querying Whether a Permissions Template Is Used
- File Moderation
- Cloud Decompression
- Batch Task Operations
- Basic Task Operations
- File List Query
File Management
- Obtaining File Details
- Adding a File Directory
- Creating File Metadata
- Obtains the upload link.
- Checking Whether File Upload Is Completed
- Obtaining Download Links
- Renaming a File
- Clearing the Recycle Bin
- Retrieving Files Using Search Engine Capabilities
- Collecting Folder Statistics
- Obtaining the Full Name and ID Paths of a File
- File Favorites
- Sharing Management - Shared by You
- Sharing Management - Shared with You
- Sharing Management - Access Links
- Collaboration Portal
- Message Notifications
- Refined Authorization
- Appendixes
- KooDrive Organizational Structure
- KooDrive Login
- KooDrive Purchase and Upgrade
- KooDrive Billing and Unsubscription
- KooDrive User Group and Member Management
KooDrive File Upload and Download
- Can I Upload and Download KooDrive Files in Batches?
- Is There a Limit on the Number or Size of KooDrive Files to be Uploaded in Batches?
- How Large a File Can I Upload in KooDrive?
- Why Are File Download Rates of KooDrive Different?
- Will the KooDrive Upload Task Be Canceled If I Refresh the Page?
- Will the File Transfer Window Automatically Disappear During File Upload in KooDrive?
- What Is the KooDrive File Upload Rate? How Is Upstream Traffic Billed?
- KooDrive File Deletion and Restoration
KooDrive File Sharing
- Can I Share KooDrive Files (Folders) with Myself?
- What Files (Folders) Are Displayed on the Shared with Me Tab Page?
- How Many KooDrive Files (Folders) Can I Share at Most Each Time?
- How Many KooDrive Records Can I Cancel for Sharing or Remove from Sharing Each Time?
- Why Is the Sharing Status Displayed as "File deleted" in KooDrive?
- Why Is the Sharing Status Displayed as "Invalid" in KooDrive?
- KooDrive Favorites
- Space Management
Individual Recycle Bin Management
Files/Folders deleted by a common user from the individual space are moved to the individual recycle bin. A common user can restore and permanently delete files/folders and clear the individual recycle bin.
The individual recycle bin is isolated from the recycle bin of each team. A common user can view the individual recycle bin, team recycle bin of their own department, and group recycle bin.
Restoring a File/Folder from the Individual Recycle Bin
- Sign in to the KooDrive service plane. Only a HUAWEI ID can be used to log in to the KooDrive service plane.
To log in as a common user, use the managed HUAWEI ID applied by the administrator for you on the console.
- In the navigation pane, choose Recycle Bin. The individual recycle bin is displayed by default.
- Restore files/folders from the individual recycle bin.
- Restoring a file/folder
Move the cursor to the row of the target file/folder and click Restore. The restoration information is displayed in the upper part of the page. The file/folder is restored to the original directory.
- Restoring files/folders
Select the target files/folders and click Restore above the list to restore them to their original directories.
- You can select up to 1,000 files/folders.
- If the original directory does not exist, a directory with the same name will be created.
- If a file/folder with the same name already exists, the restored file/folder is renamed by adding a timestamp suffix.
Permanently Deleting a File/Folder from the Individual Recycle Bin
- Permanently delete files/folders from the individual recycle bin.
- Permanently deleting a file/folder
- Move the cursor to the row of the target file/folder and click Delete Permanently.
- In the Delete Permanently dialog box, read the impact of deletion and click Yes to delete the file/folder.
- Permanently deleting files/folders
- Select the target files/folders and click Delete Permanently above the list.
- In the Delete Permanently dialog box, read the impact of deletion and click Yes to delete the files/folders.
Permanently deleted files cannot be restored.
Clearing the Individual Recycle Bin
- Click Clear above the list.
- In the Clear Recycle Bin dialog box, read the impact of clearance and click OK to clear the recycle bin.
After the recycle bin is cleared, files/folders in it cannot be restored.
