- Billing
- Getting Started
User Guide
- Before You Start
- Permissions Management
- Enabling KooDrive
- Creating an Organization and Configuring KooDrive
- KooDrive Services
- Auditing
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Department Management
- User Management
Space Management
- Listing Departments Spaces
- Querying Space Information
- Creating a Space for a Department or Individual
- Modifying Space Information
- Deleting a Space
- Querying Space Details by Space ID
- Querying Information About a Team Space
- Creating a Group Space
- Dismissing a Team Space
- Listing Group Spaces in an Enterprise
- Listing User Spaces
- Obtains space information.
- Group Management
- Session Management
- Service Subscription
- Enterprise Settings
- Other APIs
Permissions Templates
- Creating a Permissions Template
- Editing a Permissions Template
- Modifying the Status of Permissions Templates
- Deleting Permissions Templates in Batches
- Querying Permissions Template Details Based on the Permissions Template ID Array
- Listing Permissions Templates by Condition
- Adding or Modifying the Association Relationship of the Initial Member Permissions
- Querying Whether a Permissions Template Is Used
- File Moderation
- Cloud Decompression
- Batch Task Operations
- Basic Task Operations
- File List Query
File Management
- Obtaining File Details
- Adding a File Directory
- Creating File Metadata
- Obtains the upload link.
- Checking Whether File Upload Is Completed
- Obtaining Download Links
- Renaming a File
- Clearing the Recycle Bin
- Retrieving Files Using Search Engine Capabilities
- Collecting Folder Statistics
- Obtaining the Full Name and ID Paths of a File
- File Favorites
- Sharing Management - Shared by You
- Sharing Management - Shared with You
- Sharing Management - Access Links
- Collaboration Portal
- Message Notifications
- Refined Authorization
- Appendixes
- KooDrive Organizational Structure
- KooDrive Login
- KooDrive Purchase and Upgrade
- KooDrive Billing and Unsubscription
- KooDrive User Group and Member Management
KooDrive File Upload and Download
- Can I Upload and Download KooDrive Files in Batches?
- Is There a Limit on the Number or Size of KooDrive Files to be Uploaded in Batches?
- How Large a File Can I Upload in KooDrive?
- Why Are File Download Rates of KooDrive Different?
- Will the KooDrive Upload Task Be Canceled If I Refresh the Page?
- Will the File Transfer Window Automatically Disappear During File Upload in KooDrive?
- What Is the KooDrive File Upload Rate? How Is Upstream Traffic Billed?
- KooDrive File Deletion and Restoration
KooDrive File Sharing
- Can I Share KooDrive Files (Folders) with Myself?
- What Files (Folders) Are Displayed on the Shared with Me Tab Page?
- How Many KooDrive Files (Folders) Can I Share at Most Each Time?
- How Many KooDrive Records Can I Cancel for Sharing or Remove from Sharing Each Time?
- Why Is the Sharing Status Displayed as "File deleted" in KooDrive?
- Why Is the Sharing Status Displayed as "Invalid" in KooDrive?
- KooDrive Favorites
- Space Management
Show all
Previewing an Image Online
KooDrive allows you to view thumbnails of image files in multiple formats online.
- Sign in to the KooDrive service plane. Only a HUAWEI ID can be used to log in to the KooDrive service plane.
To log in as a common user, use the managed HUAWEI ID applied by the administrator for you on the console.
- Go to a file list page.
For an image file, its thumbnail and name are displayed in the File Name column.
- Click the card icon
in the upper right corner of the file list. Cloud files are displayed in the card view.
For an image file, its thumbnail is displayed on the card.
- Click the image thumbnail to display the original image.
In the upper right corner of the original image, you can zoom in, zoom out, download, or delete the image.
Click
on the left of the original image to view the previous image and
on the right to view the next one.
- Click
to close the original image.
