Downloading a File or Folder
You can download one or more files or folders from KooDrive to the local device so that you can check files anytime and anywhere. When you download folders/files in batches, the system automatically packages them for download. You can decompress the package and check the files/folders on the local device.
- Sign in to the KooDrive service plane. Only a HUAWEI ID can be used to log in to the KooDrive service plane.
To log in as a common user, use the managed HUAWEI ID applied by the administrator for you on the console.
- Go to the file list page of the individual or team space.
- Download files.
- Download a file.
Click Download in the row of the target file and check the downloaded file in Downloads of the browser.
- Downloading files or folders in batches
Select the target files or folders and click Download above the list. The message "Batch downloading..." is displayed.
After the packaging is complete, the message "Batch files are being downloaded. You can view the progress on browser's Downloads." is displayed. You can check the downloaded files or folders in Downloads of the browser.
- The system packages files/folders to be downloaded in a batch.
- Up to 700 files or folders with up to 4 GB (before compression) can be downloaded in a batch.
- Download a file.
