Uploading a File or Folder
You can upload one or more local files to KooDrive for sharing and collaboration. KooDrive uses the multipart upload function to improve file transfer efficiency. In addition, you can upload a single folder.
- If an upload task fails, the following message may be displayed in the transmission window:
- Upload failed
- File name too long.
- Insufficient space.
- Max. 200 GB
- Network error.
- If a file already uses the same name, the system automatically renames the file you uploaded with a timestamp suffix.
- A file name can contain emojis but cannot contain <>|:"*?/\. It cannot be a period (.) or double periods (..) or exceed 250 characters.
- The size of a single file to be uploaded cannot exceed 200 GB.
- A folder can contain a maximum of 1,000 files, and a maximum of 30 directory layers.
- Sign in to the KooDrive service plane. Only a HUAWEI ID can be used to log in to the KooDrive service plane.
To log in as a common user, use the managed HUAWEI ID applied by the administrator for you on the console.
- Go to the file list page of the individual or team space.
- In the file list, upload a file or folder.
- Uploading a file
- Click Upload.
- Select File.
- Select one or more files to be uploaded from your device.
- Click Open to upload the files.
- Uploading a folder
- Click Upload.
- Select Folder.
- Select a folder to be uploaded from your device.
- Click Select Folder to upload the folder.
Figure 1 Uploading files
During the upload,
displays the number of ongoing or failed upload tasks in the statistical period. You can click the icon to display the window of the upload tasks in the statistical period. Uploading (a/b) is displayed in the upper left corner of the window. b indicates the number of upload tasks created in the statistical period, and a indicates the successful tasks in the statistical period. The window is automatically hidden 3 seconds after all files are uploaded. If the upload is not complete, click
or
in the upper right corner to hide the window. If you click
again, a window is displayed, showing the upload history. If you refresh the page, a message is displayed asking you whether to reload the page. After reloading, the transmission window is cleared.During the upload, you can click
to pause an upload task or click
to cancel it. If an upload task fails, you can click
to retry it. To cancel all pending or ongoing upload tasks, click Cancel All in the upper right corner of the window. After the files are uploaded, click
to check the destination location of the uploaded files. - Uploading a file
