Help Center/ KooDrive/ User Guide/ KooDrive Services/ Common User Guide/ File Storage and Management/ Deleting Personal Files or Folders
Updated on 2025-10-13 GMT+08:00
You can delete unnecessary files or folders from the individual space.
- Sign in to the KooDrive service plane. Only a HUAWEI ID can be used to log in to the KooDrive service plane.
To log in as a common user, use the managed HUAWEI ID applied by the administrator for you on the console.
- In the navigation pane, choose My Space. The file list of your individual space is displayed.
- Delete a file or folder.
- Method 1
- Move the cursor to More in the row of the target file or folder and choose Delete.
- In the Delete File dialog box, read the impact of deletion and click OK to delete the file or folder.
- Method 2
- Select the target files or folders and click Delete above the list.
You can select up to 1,000 files or folders to delete.
- In the Delete File dialog box, read the impact of deletion and click OK to delete the files or folders.
- Deleted files or folders still occupy space.
- They are temporarily stored in the recycle bin and are not permanently deleted from KooDrive. You can restore or permanently delete them from the recycle bin.
- Method 1
Parent topic: File Storage and Management
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
