Overview
A private image contains an OS or service data, preinstalled public applications, and a user's personal applications. Private images are only available to the users who created them.
You can import an image file from your local PC or other cloud platforms to Huawei Cloud IMS and register it as a private image. Then, you can use the image to create new cloud servers or data disks, or change the OS for existing cloud servers. This way, your services can be migrated to the cloud or in the cloud.
| Image File Format | Image File Size | Helpful Link |
| VMDK, VHD, QCOW2, VHDX, QED, VDI, QCOW, or ZVHD | No larger than 128 GiB | |
| RAW or ZVHD2 | No larger than 1 TiB | |
| ISO | No larger than 128 GiB |
You can also create a private image from a cloud server or a backup. For details, see Overview.
