Help Center/ Image Management Service/ User Guide/ Managing Private Images/ Checking the Disk Capacity of an Image
Updated on 2025-12-02 GMT+08:00
You can check the disk capacity of a private image.
Check the Disk Capacity of a System Disk Image, Data Disk Image, or ISO Image
Check the disk capacity in the Disk Capacity column of the private image list.
  1. Log in to the IMS console.
  2. Click the Private Images tab to display the image list.
  3. Check the value in the Disk Capacity column. The unit is GB.
    Figure 1 Checking the disk capacity of a system disk image, data disk image, or ISO image
Check the Disk Capacity of a Full-ECS Image
The disk capacity of a full-ECS image is the sum of the system disk capacity and data disk capacity in the backup from which the full-ECS image is created.
    The value in the Disk Capacity column is --.
    Figure 2 Checking the disk capacity of a full-ECS image
  3. Click the full-ECS image name.
  4. Click the Backups tab and view the capacities of the system disk and data disks in the backup.
    Disk capacity of a full-ECS image = Capacity of the system disk in the backup + Capacity of data disks in the backup
    For example:
    • If the system disk capacity is 40 GB and no data disk is attached, the capacity of the full-ECS image disk is 40 GB.
      Figure 3 Checking backup details
    • If the system disk capacity is 40 GB and data disk capacity is 40 GB, the full-ECS image disk capacity is 80 GB.
      Figure 4 Checking backup details
