Configuring Event Alarm Notifications
You can use Cloud Eye to monitor IMS. After IMS event notifications are configured, a notification will be sent when an image is created, updated, or deleted.
Notifications are sent by the Simple Message Notification (SMN) service, which will incur charges.
- Log in to the Huawei Cloud console.
- Click
in the upper left corner of the page. In the navigation pane, choose Management & Governance > Cloud Eye. - Use either of the methods:
Method 1: In the navigation pane, choose Event Monitoring.
Method 2: In the navigation pane, choose Alarm Management > Alarm Rules.
- In the upper right corner, click Create Alarm Rule.
- Set alarm parameters by referring to Table 1.
Figure 1 Alarm parameters
Table 1 Parameters Parameter
Name
Name of the rule. The system generates a random name and you can modify it.
Description of the alarm rule.
Alarm Type
Select Event.
Event Type
Select System event.
Event Source
Select Image Management Service.
Monitoring Scope
Specify the resource scope that the alarm rule will apply to.
Method
Use the default value Configure manually.
Alarm Policy
Configure a policy for triggering an alarm. You can configure a policy for triggering an alarm when an image is created, updated, or deleted.
Notified By
Select an option as you need.
NOTE:Alarm messages are sent by SMN, which may incur a small charge.
- Click Create. In the displayed dialog box, click OK.
