Updated on 2026-06-01 GMT+08:00
IMS Operations Audited by CTS
Cloud Trace Service (CTS) is a log audit service provided by Huawei Cloud and intended for cloud security. It allows you to collect, store, and query cloud resource operation records and use these records for security analysis, compliance auditing, resource tracking, and fault locating.
You can use CTS to record IMS operations for later querying, auditing, and backtracking.
You need to enable CTS before using it. If it is not enabled, IMS operations cannot be recorded. After being enabled, CTS automatically creates a tracker to record all your operations. The tracker stores only the operations of the last seven days. To store the operations for a longer time, store trace files in OBS buckets. For details, see Enabling CTS.
IMS Operations Recorded by CTS
Table 1 IMS operations that can be recorded by CTS
Operation
Resource Type
Trace Name
Creating an image
ims
createImage
Creating a data disk image
ims
createDataImage
Creating a full-ECS image
ims
createWholeImage
Modifying an image
ims
updateImage
Deleting images
ims
deleteImage
Querying details about an image
ims
queryImage
Querying details about images
ims
listImages
Replicating an image
ims
copyImage
Replicating an image across regions
ims
crossRegionCopyImage
Exporting an image
ims
exportImage
Adding image recipients
ims
addMember
Updating the image sharing status of an image recipient
ims
updateMember
Deleting image recipients
ims
deleteMember
Querying details about an image recipient
ims
queryMember
Querying image recipients
ims
listMembers
Adding or modifying an image tag
ims
createOrUpdateTags
Adding or deleting image tags
ims
batchAddOrDeleteImageTag
Adding an image tag
ims
createTag
Deleting image tags
ims
deleteTags
Deleting an image tag
ims
deleteTag
Querying image tags
ims
listTags
Creating image metadata
ims
createImageMetadata
Register an image file as a private image
ims
registerImage
Uploading an image
ims
uploadImage
Querying the image schema
ims
queryImageSchema
Querying the image list schema
ims
queryImageListSchema
Querying the image recipient schema
ims
queryMemberSchema
Querying an image recipient list schema
ims
queryMemberListSchema
Querying OSs supported by images
ims
listOsVersions
Querying image quotas
ims
queryImageQuota
Table 2 Relationship between IMS operations and native OpenStack APIs
Operation
Trace Name
Service Type
Resource Type
OpenStack Component
Creating an Image
createImage
IMS
glance
Modifying/Uploading an image
updateImage
IMS
glance
Deleting an image
deleteImage
IMS
glance
Tagging an image
addTag
IMS
glance
deleteTag
IMS
glance
addMember
IMS
glance
updateMember
IMS
glance
deleteMember
IMS
glance
