Exporting an Image List
You can export the public or private image list in the current region as a CSV file to your local PC.
- For public images, the file contains the image name, ID, status, OS, image type, disk capacity, boot mode, creation time, and minimum memory.
- For private images, the file contains the image name, ID, status, OS, image type, creation time, disk capacity, image size, release status, encryption status, boot mode, and other information.
Exporting Public Image Information
- Log in to the IMS console.
- On the Public Images tab, click Export above the image list, and select Export all data to an XLSX file.
The system will automatically export the list of all public images in the current region to a local directory.
Figure 1 Exporting public image information
Exporting Private Image Information
- On the Private Images tab, select the target images to be exported and choose Export > Export selected data to an XLSX file. above the image list.
The system will automatically export the list of selected private images in the current region under your account to a local directory.
Figure 2 Exporting private image information
