Updated on 2026-06-30 GMT+08:00
Managing Tags
You can use tags to classify images. You can add, modify, or delete image tags, or search for required images by tag in the image list.
- When adding predefined tags to an image or searching for an image using predefined tags, you must have permission to access the Tag Management Service (TMS).
- If your organization has configured tag policies for images, you need to add tags to your images based on the policies. Otherwise, tags may fail to be added. For details about image tag format, see Image Tag Format.
A maximum of 20 tags can be added to each image. The actual number of supported tags will be displayed on the console.
Add, Delete, and Modify Image Tags
- Log in to the IMS console.
- On the Private Images tab, click the target image name to go to its details page.
- On the Tags tab, click Edit Tag. In the slide-out panel, click
in the tag key or tag value text box, select a predefined tag from the drop-down list, and click OK. Figure 1 Editing a tag
- On the Tags tab, click Edit Tag. In the slide-out panel, locate the target tag to be deleted and click Delete and then OK. Figure 2 Deleting a tag
- On the Tags tab, click Edit Tag. In the slide-out panel, click Add, select a predefined tag from the drop-down list, and click OK. Figure 3 Adding a tag
Search for Private Images by Tag
- Click the Private Images tab and click the search box above the private image list. Under Resource Tag, specify the tag key and value to search for images.
- Neither the tag key nor tag value can be empty. When the tag key and tag value are matched, the system automatically shows your desired private images.
- You can add multiple tags to search for private images. The system will display private images that match all tags.
Figure 4 Searching for images by resource tag
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
