- What's New
- Function Overview
- Getting Started
User Guide
- Using IAM to Grant Access to IMS
Creating a Private Image
- Introduction
- Creating a System Disk Image from a Windows ECS
- Creating a System Disk Image from a Linux ECS
- Creating a Windows System Disk Image from an External Image File
- Creating a Linux System Disk Image from an External Image File
- Creating a BMS System Disk Image
- Creating a Data Disk Image from an ECS
- Creating a Data Disk Image from an External Image File
- Creating a Full-ECS Image from an ECS
- Creating a Full-ECS Image from a CSBS Backup
- Creating a Full-ECS Image from a CBR Backup
- Creating a Windows System Disk Image from an ISO File
- Creating a Linux System Disk Image from an ISO File
- Importing an Image
- Fast Import of an Image File
Managing Private Images
- Creating an ECS from an Image
- Modifying an Image
- Exporting an Image
- Exporting Image List
- Checking the Disk Capacity of an Image
- Deleting Images
Sharing Images
- Overview
- Obtaining the Project ID, Account ID, and Organization URN
- Sharing Specified Images
- Accepting or Rejecting Shared Images
- Rejecting Accepted Images
- Accepting Rejected Images
- Stopping Sharing Images
- Adding Tenants Who Can Use Shared Images
- Deleting Image Recipients Who Can Use Shared Images
- Replicating a Shared Image
- Replicating Images Within a Region
- Replicating Images Across Regions
- Optimizing a Windows Private Image
Optimizing a Linux Private Image
- Optimization Process
- Checking Whether a Private Image Needs to be Optimized
- Using a Script to Optimize a Xen Private Image
- Uninstalling PV Drivers from a Linux ECS
- Changing Disk Identifiers in the GRUB File to UUID
- Changing Disk Identifiers in the fstab File to UUID
- Installing Native Xen and KVM Drivers
- Installing Native KVM Drivers
- Clearing System Logs
- Encrypting Images
- Windows Operations
- Linux Operations
- Managing Public Images
- Managing Tags
- Managing Quotas
- Auditing Key Operations
Best Practices
- Overview
- Creating a Windows Image Using VirtualBox and an ISO File
- Creating a Linux Image Using VirtualBox and an ISO File
- Cleaning Up the Disk Space of a Windows ECS
- Converting the Image Format
- Creating a Private Image Using Packer
- Configuring an ISO File as a Local Image Source
- Migrating ECSs Across Accounts and Regions
- Migrating Service Data Across Accounts (Data Disks)
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Native OpenStack APIs
- Examples
- Common Parameters
Historical APIs
Image (Native OpenStack APIs)
- Querying Images (Native OpenStack API V2, Discarded)
- Querying Image Details (Native OpenStack API V2, Discarded)
- Modifying an Image (Native OpenStack API V2, Discarded)
- Uploading an Image (Native OpenStack API V2, Discarded)
- Deleting an Image (Native OpenStack API V1.1, Discarded)
- Querying Image Metadata (Native OpenStack API V1, Discarded)
- Querying Image Details (Native OpenStack API V1.1, Discarded)
- Image Tagging (Native OpenStack APIs)
- Image Sharing (Native OpenStack APIs)
- Status Codes
- Error Codes
- SDK Reference
Image Consulting
- How Do I Select an Image?
- What Do I Do If I Cannot Find a Desired Image?
- Are There Any Public Images Already Containing Certain Applications, Such as OpenVPN or PyTorch?
- What Are the Differences Between Images and Backups?
- Can I Tailor an Image?
- How Do I Migrate an ECS to a Different Region of Another Account?
- How Can I Back Up the Current Status of an ECS for Restoration in the Case of a System Fault?
- How Can I Apply a Private Image to an Existing ECS?
- Can I Import Data from a Data Disk Image to a Data Disk?
- Can I Use Private Images of Other Accounts?
- End-of-Support for OSs
Image Creation
- General Creation FAQ
- Full-ECS Image FAQ
- How Can I Use a Backup to Create an EVS Disk or ECS?
- Is There Any Difference Between the Image Created from a CSBS/CBR Backup and That Created from an ECS?
- Why Can't I Find an ISO Image When I Want to Use It to Create an ECS or Change the OS of an ECS?
- How Do I Create a Full-ECS Image Using an ECS That Has a Spanned Volume?
- Why Is Sysprep Required for Creating a Private Image from a Windows ECS?
- How Do I Handle the Startup Failure of a Windows ECS Created from a Windows Image Generalized by Sysprep?
- What Do I Do If I Cannot Create an Image in ZVHD2 Format Using an API?
- Image Sharing
OS
- How Do I Select an OS?
- How Is BIOS Different from UEFI?
- What Do I Do If I Cannot Change the Resolution of a Windows OS Booted in UEFI Mode?
- How Do I Delete Redundant Network Connections from a Windows ECS?
- What Do I Do If an ECS Starts Slowly?
- What Do I Do If the One-Click Password Resetting Plug-In Failed to Start?
- Why Can't I Find My Private Image When I Want to Use It to Create an ECS or Change the OS of an ECS?
Image Import
- Can I Use Images in Formats not Described in This Document?
- What Are the Impacts If I Do Not Pre-configure an ECS Used to Create a Private Image?
- How Do I Import an OVF or OVA File to the Cloud Platform?
- What Do I Do If I Chose the Wrong OS or System Disk Capacity When Registering a Private Image?
- Why Did My VHD Upload Fail? Why Does the System Say the System Disk in the VHD Image File Is Larger Than What I Specified on the Management Console?
- How Do I Import Existing Huawei Cloud Private Images to a Specified Region?
Image Export
- Can I Download My Private Images to a Local PC?
- Can I Use the System Disk Image of an ECS on a BMS After I Export It from the Cloud Platform?
- Why Is the Image Size in an OBS Bucket Different from That Displayed in IMS?
- Can I Download a Public Image to My PC?
- What Are the Differences Between Import/Export and Fast Import/Export?
- Why the Export Option Is Unavailable for My Image?
Image Optimization
- Must I Install Guest OS Drivers on an ECS?
- Why Do I Need to Install and Update VirtIO Drivers for Windows?
- What Will the System Do to an Image File When I Use the File to Register a Private Image?
- How Do I Configure an ECS, a BMS, or an Image File Before I Use It to Create an Image?
- What Do I Do If a Windows Image File Is Not Pre-Configured When I Use It to Register a Private Image?
- What Do I Do If a Linux Image File Is Not Pre-Configured When I Use It to Register a Private Image?
- How Do I Optimize an Image?
- How Do I Use a Private Image Created from a First-Generation ECS to Create a Second-Generation ECS?
- How Do I Enable NIC Multi-Queue for an Image?
- How Do I Configure an ECS to Use DHCPv6?
- How Do I Make a System Disk Image Support Fast ECS Creation?
- Why Did I Fail to Install Guest OS Drivers on a Windows ECS?
- How Do I Install Native Xen and KVM Drivers?
- Image Replication
- Image Deletion
- Image Encryption
- KooGallery Images
- Accounts and Permissions
- Cloud-Init
ECS Creation
- Can I Change the Image of a Purchased ECS?
- Can I Change the Specifications Defined by a Private Image When I Use the Image to Create an ECS?
- Can I Specify the System Disk Capacity When I Create an ECS Using an Image?
- What Do I Do If a Partition Is Not Found During the Startup of an ECS Created from an Imported Private Image?
- What Do I Do If the Disks of a CentOS ECS Created from an Image Cannot Be Found?
- What Do I Do If I Enabled Automatic Configuration During Image Registration for an ECS Created from a Windows Image and Now It Won't Start?
- What Do I Do If an Exception Occurs When I Start an ECS Created from an Image Using UEFI Boot?
Driver Installation
- How Do I Install PV Drivers in Windows?
- How Do I Install VirtIO Drivers in Windows?
- How Do I Install Native KVM Drivers in Linux?
- Image Tags
- Billing
Image Consulting
- Videos
- Glossary
More Documents
- Overview
- Introduction
- Deleting Images
Sharing Images
- Overview
- Obtaining the Account Name and Project Name
- Encrypting Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
- Basic Concepts
Image Creation
- Image Sharing
- OS
Image Import
Image Export
Image Optimization
- How Do I Configure an ECS or an Image File Before I Use It to Create an Image?
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
- Billing
Image Consulting
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Querying Images (Native OpenStack API)
- Querying Image Details (Native OpenStack API)
- Updating Image Information (Native OpenStack API)
- Uploading an Image (Native OpenStack API)
- Deleting an Image (Native OpenStack API)
- Creating Image Metadata (Native OpenStack API)
- Deleting an Image (Native OpenStack API v1.1 - Abandoned and Not Recommended)
- Querying Image Metadata (Native OpenStack API v1 - Abandoned and Not Recommended)
- Querying Image Details (Native OpenStack API v1.1 - Abandoned and Not Recommended)
- Image Schema (Native OpenStack APIs)
- API Version Query (Native OpenStack API)
- Examples
- Permission Policies and Supported Actions
- Common Parameters
- Status Codes
- Error Codes
- Change History
User Guide (Paris Regions)
- Overview
- Introduction
- Deleting Images
- Sharing Images
- Encrypting Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
- Basic Concepts
Image Creation
- Image Sharing
OS
- What Do I Do If a Windows 7 ECS Equipped with an Intel 82599 NIC Reports an Error in SR-IOV Scenarios?
Image Import
Image Export
Image Optimization
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
Image Consulting
API Reference (Paris Regions)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Examples
- API Actions
- Common Parameters
- Status Codes
- Error Codes
- Change History
- Overview
- Introduction
- Deleting Images
Sharing Images
- Overview
- Encrypting Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
- Basic Concepts
Image Creation
- Image Sharing
- OS
Image Import
Image Export
Image Optimization
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
Image Consulting
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Examples
- Common Parameters
- Status Codes
- Error Codes
- Change History
User Guide (Ankara Region)
- Overview
- Introduction
- Deleting Images
- Sharing Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
Image Creation
- Image Sharing
OS
Image Import
Image Export
Image Optimization
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
Image Consulting
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Examples
- Common Parameters
- Status Codes
- Error Codes
- Change History
On this page
Show all
Help Center/
Image Management Service/
User Guide/
Managing Private Images/
Parent topic: Managing Private Images
