Updated on 2025-08-26 GMT+08:00
Adding Tenants Who Can Use Shared Images
In addition to the tenants you have shared images with, you can add more tenants who can use the shared images.
  • You have shared private images.
  • You have obtained the project IDs, account IDs, or organization URNs of the tenants to be added.
  1. Access the IMS console.
    2. Under Compute, click Image Management Service.
      The IMS console is displayed.
  2. Click the Private Images tab.
  3. Click the image name to view image details.
  4. Click Add Tenant.
  5. In the Add Tenant dialog box, enter the project ID, account ID, or organization URN of the tenant to be added, and click OK.
    To add multiple tenants, enter their project IDs, account IDs, or organization URNs and separate them with commas (,). Click OK.
    • You can share images only within the region where they reside. To share an image across regions, you need to replicate the image to the target region first.
    • A project ID uniquely identifies a tenant in a specific region. If you enter a project ID that belongs to a different region from the images, a message will display indicating that the tenant cannot be found.
