Help Center/ Image Management Service/ User Guide/ Managing Private Images/ Sharing Images/ Rejecting Accepted Images
Updated on 2026-06-30 GMT+08:00
You can reject accepted images if you no longer need them.
After an image is rejected, it will not be displayed on the Images Shared with Me page.
You have accepted images shared by other users.
- Log in to the IMS console.
- Click the Images Shared with Me tab.
- Determine the next step based on how many images you are to reject.
- To reject a specific image: locate the image to be rejected and click Reject in the Operation column. In the displayed dialog box, click OK.
- To reject multiple images: select the images to be rejected and click Reject above the image list. In the displayed dialog box, click OK.
