Deleting Images
You can delete private images that will no longer be used.
- Deleted private images cannot be retrieved. Perform this operation only when absolutely necessary.
- After a private image is deleted, it cannot be used to create ECSs or EVS disks.
- After a private image is deleted, ECSs created from the image can still be used and are still billed. However, the OS cannot be reinstalled for the ECSs and ECSs with the same configuration cannot be created.
- Deleting the source image of a replicated image has no effect on the replicated image. Similarly, deleting a replicated image has no effect on its source.
- If a full-ECS image is still being created when you delete it, some intermediate backups may fail to be deleted. To avoid generating any unnecessary expenditures, you can delete them on the CSBS or CBR console.
- Private images that have been published in KooGallery cannot be deleted.
- If an image is shared with an account or organization, you need first to remove the account or organization from the image recipients before you delete the image.
- Log in to the IMS console.
- Click the Private Images tab to display the image list.
- Locate the row that contains the image, choose More > Delete in the Operation column.
To delete multiple images:
- Select the images you want to delete in the image list.
- Click Delete above the image list.
- (Optional) Select Delete CSBS backups or cloud server backups of the full-ECS images.
This parameter is available only when you have selected full-ECS images from the image list.
If you select this option, the system will delete CSBS or CBR backups of the full-ECS images. After the CSBS backups or CBR backups are deleted, they are no longer billed.
If CSBS or CBR backups are not deleted, they will continue to be billed. You can delete them later on the CSBS or CBR console.
- Enter DELETE to confirm the deletion. Click OK. The images and associated resources (if any) are deleted immediately.
