Updated on 2026-06-01 GMT+08:00
Configuring the ECS and Creating a Linux System Disk Image
After installing an OS for the temporary ECS, configure the ECS and install Xen and KVM drivers to ensure that ECSs created from this temporary ECS can work properly.
This section describes how to configure a Linux ECS, install drivers, and create a Linux system disk image.
  1. Configure the ECS.
    1. Configure the network.
      • Run the ifconfig command to check whether the private IP address of the ECS is the same as that displayed on the console. If they are inconsistent, delete files from the network rule directory as instructed in Deleting Files from the Network Rule Directory.
      • Check whether DHCP is configured. If the ECS is configured with a static IP address, change its IP address assignment to DHCP as instructed in Configuring DHCP.
      • Run the service sshd status command to check whether SSH is enabled. If it is disabled, run the service sshd start command to enable it. Ensure that your ECS firewall, for example, Linux iptables, allows access to SSH.
    2. Install drivers.
      To ensure that the network performance and basic functions of the ECSs created from the private image are normal, install native Xen and KVM drivers on the ECS used to create the image. Before installing native Xen and KVM drivers, uninstall PV drivers.
      Disable your antivirus and intrusion detection software. You can enable them after the driver installation is complete.
    3. Configure a file system.
    4. (Optional) Configure value-added functions.
  2. Create a Linux system disk image.
    For details, see Creating a System Disk Image from an ECS.
Follow-up Procedure
After the system disk image is created, delete the temporary ECS in a timely manner to avoid generating any additional charges.
