- What's New
- Function Overview
- Getting Started
User Guide
- Using IAM to Grant Access to IMS
Creating a Private Image
- Introduction
- Creating a System Disk Image from a Windows ECS
- Creating a System Disk Image from a Linux ECS
- Creating a Windows System Disk Image from an External Image File
- Creating a Linux System Disk Image from an External Image File
- Creating a BMS System Disk Image
- Creating a Data Disk Image from an ECS
- Creating a Data Disk Image from an External Image File
- Creating a Full-ECS Image from an ECS
- Creating a Full-ECS Image from a CSBS Backup
- Creating a Full-ECS Image from a CBR Backup
- Creating a Windows System Disk Image from an ISO File
- Creating a Linux System Disk Image from an ISO File
- Importing an Image
- Fast Import of an Image File
Managing Private Images
- Creating an ECS from an Image
- Modifying an Image
- Exporting an Image
- Exporting Image List
- Checking the Disk Capacity of an Image
- Deleting Images
Sharing Images
- Overview
- Obtaining the Project ID, Account ID, and Organization URN
- Sharing Specified Images
- Accepting or Rejecting Shared Images
- Rejecting Accepted Images
- Accepting Rejected Images
- Stopping Sharing Images
- Adding Tenants Who Can Use Shared Images
- Deleting Image Recipients Who Can Use Shared Images
- Replicating a Shared Image
- Replicating Images Within a Region
- Replicating Images Across Regions
- Optimizing a Windows Private Image
Optimizing a Linux Private Image
- Optimization Process
- Checking Whether a Private Image Needs to be Optimized
- Using a Script to Optimize a Xen Private Image
- Uninstalling PV Drivers from a Linux ECS
- Changing Disk Identifiers in the GRUB File to UUID
- Changing Disk Identifiers in the fstab File to UUID
- Installing Native Xen and KVM Drivers
- Installing Native KVM Drivers
- Clearing System Logs
- Encrypting Images
- Windows Operations
- Linux Operations
- Managing Public Images
- Managing Tags
- Managing Quotas
- Auditing Key Operations
Best Practices
- Overview
- Creating a Windows Image Using VirtualBox and an ISO File
- Creating a Linux Image Using VirtualBox and an ISO File
- Cleaning Up the Disk Space of a Windows ECS
- Converting the Image Format
- Creating a Private Image Using Packer
- Configuring an ISO File as a Local Image Source
- Migrating ECSs Across Accounts and Regions
- Migrating Service Data Across Accounts (Data Disks)
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Native OpenStack APIs
- Examples
- Common Parameters
Historical APIs
Image (Native OpenStack APIs)
- Querying Images (Native OpenStack API V2, Discarded)
- Querying Image Details (Native OpenStack API V2, Discarded)
- Modifying an Image (Native OpenStack API V2, Discarded)
- Uploading an Image (Native OpenStack API V2, Discarded)
- Deleting an Image (Native OpenStack API V1.1, Discarded)
- Querying Image Metadata (Native OpenStack API V1, Discarded)
- Querying Image Details (Native OpenStack API V1.1, Discarded)
- Image Tagging (Native OpenStack APIs)
- Image Sharing (Native OpenStack APIs)
- Status Codes
- Error Codes
- SDK Reference
Image Consulting
- How Do I Select an Image?
- What Do I Do If I Cannot Find a Desired Image?
- Are There Any Public Images Already Containing Certain Applications, Such as OpenVPN or PyTorch?
- What Are the Differences Between Images and Backups?
- Can I Tailor an Image?
- How Do I Migrate an ECS to a Different Region of Another Account?
- How Can I Back Up the Current Status of an ECS for Restoration in the Case of a System Fault?
- How Can I Apply a Private Image to an Existing ECS?
- Can I Import Data from a Data Disk Image to a Data Disk?
- Can I Use Private Images of Other Accounts?
- End-of-Support for OSs
Image Creation
- General Creation FAQ
- Full-ECS Image FAQ
- How Can I Use a Backup to Create an EVS Disk or ECS?
- Is There Any Difference Between the Image Created from a CSBS/CBR Backup and That Created from an ECS?
- Why Can't I Find an ISO Image When I Want to Use It to Create an ECS or Change the OS of an ECS?
- How Do I Create a Full-ECS Image Using an ECS That Has a Spanned Volume?
- Why Is Sysprep Required for Creating a Private Image from a Windows ECS?
- How Do I Handle the Startup Failure of a Windows ECS Created from a Windows Image Generalized by Sysprep?
- What Do I Do If I Cannot Create an Image in ZVHD2 Format Using an API?
- Image Sharing
OS
- How Do I Select an OS?
- How Is BIOS Different from UEFI?
- What Do I Do If I Cannot Change the Resolution of a Windows OS Booted in UEFI Mode?
- How Do I Delete Redundant Network Connections from a Windows ECS?
- What Do I Do If an ECS Starts Slowly?
- What Do I Do If the One-Click Password Resetting Plug-In Failed to Start?
- Why Can't I Find My Private Image When I Want to Use It to Create an ECS or Change the OS of an ECS?
Image Import
- Can I Use Images in Formats not Described in This Document?
- What Are the Impacts If I Do Not Pre-configure an ECS Used to Create a Private Image?
- How Do I Import an OVF or OVA File to the Cloud Platform?
- What Do I Do If I Chose the Wrong OS or System Disk Capacity When Registering a Private Image?
- Why Did My VHD Upload Fail? Why Does the System Say the System Disk in the VHD Image File Is Larger Than What I Specified on the Management Console?
- How Do I Import Existing Huawei Cloud Private Images to a Specified Region?
Image Export
- Can I Download My Private Images to a Local PC?
- Can I Use the System Disk Image of an ECS on a BMS After I Export It from the Cloud Platform?
- Why Is the Image Size in an OBS Bucket Different from That Displayed in IMS?
- Can I Download a Public Image to My PC?
- What Are the Differences Between Import/Export and Fast Import/Export?
- Why the Export Option Is Unavailable for My Image?
Image Optimization
- Must I Install Guest OS Drivers on an ECS?
- Why Do I Need to Install and Update VirtIO Drivers for Windows?
- What Will the System Do to an Image File When I Use the File to Register a Private Image?
- How Do I Configure an ECS, a BMS, or an Image File Before I Use It to Create an Image?
- What Do I Do If a Windows Image File Is Not Pre-Configured When I Use It to Register a Private Image?
- What Do I Do If a Linux Image File Is Not Pre-Configured When I Use It to Register a Private Image?
- How Do I Optimize an Image?
- How Do I Use a Private Image Created from a First-Generation ECS to Create a Second-Generation ECS?
- How Do I Enable NIC Multi-Queue for an Image?
- How Do I Configure an ECS to Use DHCPv6?
- How Do I Make a System Disk Image Support Fast ECS Creation?
- Why Did I Fail to Install Guest OS Drivers on a Windows ECS?
- How Do I Install Native Xen and KVM Drivers?
- Image Replication
- Image Deletion
- Image Encryption
- KooGallery Images
- Accounts and Permissions
- Cloud-Init
ECS Creation
- Can I Change the Image of a Purchased ECS?
- Can I Change the Specifications Defined by a Private Image When I Use the Image to Create an ECS?
- Can I Specify the System Disk Capacity When I Create an ECS Using an Image?
- What Do I Do If a Partition Is Not Found During the Startup of an ECS Created from an Imported Private Image?
- What Do I Do If the Disks of a CentOS ECS Created from an Image Cannot Be Found?
- What Do I Do If I Enabled Automatic Configuration During Image Registration for an ECS Created from a Windows Image and Now It Won't Start?
- What Do I Do If an Exception Occurs When I Start an ECS Created from an Image Using UEFI Boot?
Driver Installation
- How Do I Install PV Drivers in Windows?
- How Do I Install VirtIO Drivers in Windows?
- How Do I Install Native KVM Drivers in Linux?
- Image Tags
- Billing
Image Consulting
- Videos
- Glossary
More Documents
- Overview
- Introduction
- Deleting Images
Sharing Images
- Overview
- Obtaining the Account Name and Project Name
- Encrypting Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
- Basic Concepts
Image Creation
- Image Sharing
- OS
Image Import
Image Export
Image Optimization
- How Do I Configure an ECS or an Image File Before I Use It to Create an Image?
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
- Billing
Image Consulting
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Querying Images (Native OpenStack API)
- Querying Image Details (Native OpenStack API)
- Updating Image Information (Native OpenStack API)
- Uploading an Image (Native OpenStack API)
- Deleting an Image (Native OpenStack API)
- Creating Image Metadata (Native OpenStack API)
- Deleting an Image (Native OpenStack API v1.1 - Abandoned and Not Recommended)
- Querying Image Metadata (Native OpenStack API v1 - Abandoned and Not Recommended)
- Querying Image Details (Native OpenStack API v1.1 - Abandoned and Not Recommended)
- Image Schema (Native OpenStack APIs)
- API Version Query (Native OpenStack API)
- Examples
- Permission Policies and Supported Actions
- Common Parameters
- Status Codes
- Error Codes
- Change History
User Guide (Paris Regions)
- Overview
- Introduction
- Deleting Images
- Sharing Images
- Encrypting Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
- Basic Concepts
Image Creation
- Image Sharing
OS
- What Do I Do If a Windows 7 ECS Equipped with an Intel 82599 NIC Reports an Error in SR-IOV Scenarios?
Image Import
Image Export
Image Optimization
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
Image Consulting
API Reference (Paris Regions)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Examples
- API Actions
- Common Parameters
- Status Codes
- Error Codes
- Change History
- Overview
- Introduction
- Deleting Images
Sharing Images
- Overview
- Encrypting Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
- Basic Concepts
Image Creation
- Image Sharing
- OS
Image Import
Image Export
Image Optimization
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
Image Consulting
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Examples
- Common Parameters
- Status Codes
- Error Codes
- Change History
User Guide (Ankara Region)
- Overview
- Introduction
- Deleting Images
- Sharing Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
Image Creation
- Image Sharing
OS
Image Import
Image Export
Image Optimization
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
Image Consulting
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Examples
- Common Parameters
- Status Codes
- Error Codes
- Change History
Registering an External Image File as a Private Image
Register an image file uploaded to the OBS bucket as a private image.
- Access the IMS console.
- Under Compute, click Image Management Service.
The IMS console is displayed.
- Register an external image file as a private image.
- Click Create Image in the upper right corner.
- Set image parameters.
Table 1 and Table 2 list the parameters in the Image Type and Source and Image Information areas, respectively.
Table 1 Image type and source Parameter
Type
Select Import Image.
Region
Select a region close to where your services will be provided.
If you select an incorrect region here, you can replicate the created image to your desired region later. For details, see Replicating an Image Across Regions.
Image Type
Select System disk image.
Source
Select the bucket storing the image file from the list and then select the image file.
Enable Fast Create
This parameter is available only when you select a ZVHD2 or RAW image file.
This function enables fast image creation and supports import of large files (maximum: 1 TB) as long as the files to be uploaded are converted to ZVHD2 or RAW format and optimized. If you have a file that meets the requirements, select Enable Fast Create and select the confirmation information following Image File Preparation.
To learn how to convert image file formats and generate bitmap files, see Fast Import of an Image File.
Table 2 Image information Parameter
Enable automatic configuration
If you select this option, the system will automatically check and optimize the image file. For details, see What Will the System Do to an Image File When I Use the File to Register a Private Image?
Function
Specifies whether the image is used to create ECSs or BMSs. The value can be ECS system disk image or BMS system disk image. This section uses ECS system disk image as an example.
Architecture
The value can be x86 or ARM.
- If the system identifies that the architecture in the image file is different from what you set here, the identified architecture prevails.
- If the system fails to identify an architecture, the architecture you set will be used.
Boot Mode
This parameter is optional. The value can be BIOS or UEFI. For details about the differences between them, see How Is BIOS Different from UEFI?
For details about which OSs support UEFI boot, see OSs supporting UEFI Boot Mode.
The boot mode must be the same as that in the image file. You need to confirm which boot mode is used in the image file. After you select the right boot mode, the boot mode will be configured for the image at the background. Select the right boot mode, or ECSs created using the image will not be able to boot up.
OS
To ensure that the image can be created and used properly, select an OS consistent with that in the image file. If you do not select an OS, the system attempts to automatically identify the OS in the image file.
- If the system identifies that the OS in the image file is different from the one you select here, the identified OS prevails.
- If the system fails to identify an OS, the OS you select will be used.
- If the OS you selected or identified by the system is inconsistent with the actual one, ECSs created from the image file may not work properly.
License Type
Bring Your Own License (BYOL) is supported. If you have obtained an OS license, you do not need to apply for a license any more.
System Disk (GB)
The system disk capacity (value range: 40 GB to 1024 GB). Ensure that this value is not less than the system disk capacity in the image file.
If the uploaded VHD image is generated using qemu-img or similar tools, check the system disk capacity based on What Do I Do If the System Disk Capacity in a VHD Image File Exceeds the One I Have Specified on the Management Console When I Use This File to Register a Private Image?
Data Disk (GB)
You can also add data disks to the image. You need to obtain an image file containing data disks in advance. This function is used to migrate VMs and data disks from other platforms to the current platform.
To add data disks, click
, configure the data disk capacity, and click Select Image File. In the displayed dialog box, select the target bucket and then the target image file containing the data disk.
A maximum of three data disks can be added.
Name
Set a name for the image.
Encryption
(Optional) If you want to encrypt the image, select KMS encryption and select the key to be used from the key list. After you select KMS encryption, the system will create a default key ims/default for you. You can also select a key from the key list.
For how to encrypt an image, see Creating Encrypted Images.
Enterprise Project
Select an enterprise project from the drop-down list. This parameter is available only if you have enabled enterprise projects or your account is an enterprise account.
An enterprise project provides central management of cloud resources on a project by project basis.
Tag
(Optional) Set a tag key and a tag value for the image to make identification and management of your images easier.
If your organization has configured tag policies for images, you need to add tags to your images based on the policies. If you do not comply with the tag policies, images may fail to be created. Contact the organization administrator to learn more about the tag policies.
- Each tag consists of a key and a value. The key contains a maximum of 36 characters, and the value contains a maximum of 43 characters. The key cannot be left blank or an empty string. The value cannot be left blank but can be an empty string.
- An image can have a maximum of 10 tags.
(Optional) Enter a description of the image.
- Click Next and confirm the image specifications. Select Statement of Commitment to Image Creation and Huawei Image Disclaimer. Click Submit.
- Go back to the Private Images page. The image is successfully registered when its status becomes Normal.
If you add data disks during image creation, a system disk image and data disk images will be generated. The number of data disk images depends on the number of data disks you add (a maximum of 3).
The time required for image registration is determined by the image file size. You may need to wait a long period of time for the image file to be successfully registered as a private image.
