- What's New
- Function Overview
- Getting Started
User Guide
- Using IAM to Grant Access to IMS
Creating a Private Image
- Introduction
- Creating a System Disk Image from a Windows ECS
- Creating a System Disk Image from a Linux ECS
- Creating a Windows System Disk Image from an External Image File
- Creating a Linux System Disk Image from an External Image File
- Creating a BMS System Disk Image
- Creating a Data Disk Image from an ECS
- Creating a Data Disk Image from an External Image File
- Creating a Full-ECS Image from an ECS
- Creating a Full-ECS Image from a CSBS Backup
- Creating a Full-ECS Image from a CBR Backup
- Creating a Windows System Disk Image from an ISO File
- Creating a Linux System Disk Image from an ISO File
- Importing an Image
- Fast Import of an Image File
Managing Private Images
- Creating an ECS from an Image
- Modifying an Image
- Exporting an Image
- Exporting Image List
- Checking the Disk Capacity of an Image
- Deleting Images
Sharing Images
- Overview
- Obtaining the Project ID, Account ID, and Organization URN
- Sharing Specified Images
- Accepting or Rejecting Shared Images
- Rejecting Accepted Images
- Accepting Rejected Images
- Stopping Sharing Images
- Adding Tenants Who Can Use Shared Images
- Deleting Image Recipients Who Can Use Shared Images
- Replicating a Shared Image
- Replicating Images Within a Region
- Replicating Images Across Regions
- Optimizing a Windows Private Image
Optimizing a Linux Private Image
- Optimization Process
- Checking Whether a Private Image Needs to be Optimized
- Using a Script to Optimize a Xen Private Image
- Uninstalling PV Drivers from a Linux ECS
- Changing Disk Identifiers in the GRUB File to UUID
- Changing Disk Identifiers in the fstab File to UUID
- Installing Native Xen and KVM Drivers
- Installing Native KVM Drivers
- Clearing System Logs
- Encrypting Images
- Windows Operations
- Linux Operations
- Managing Public Images
- Managing Tags
- Managing Quotas
- Auditing Key Operations
Best Practices
- Overview
- Creating a Windows Image Using VirtualBox and an ISO File
- Creating a Linux Image Using VirtualBox and an ISO File
- Cleaning Up the Disk Space of a Windows ECS
- Converting the Image Format
- Creating a Private Image Using Packer
- Configuring an ISO File as a Local Image Source
- Migrating ECSs Across Accounts and Regions
- Migrating Service Data Across Accounts (Data Disks)
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Native OpenStack APIs
- Examples
- Common Parameters
Historical APIs
Image (Native OpenStack APIs)
- Querying Images (Native OpenStack API V2, Discarded)
- Querying Image Details (Native OpenStack API V2, Discarded)
- Modifying an Image (Native OpenStack API V2, Discarded)
- Uploading an Image (Native OpenStack API V2, Discarded)
- Deleting an Image (Native OpenStack API V1.1, Discarded)
- Querying Image Metadata (Native OpenStack API V1, Discarded)
- Querying Image Details (Native OpenStack API V1.1, Discarded)
- Image Tagging (Native OpenStack APIs)
- Image Sharing (Native OpenStack APIs)
- Status Codes
- Error Codes
- SDK Reference
Image Consulting
- How Do I Select an Image?
- What Do I Do If I Cannot Find a Desired Image?
- Are There Any Public Images Already Containing Certain Applications, Such as OpenVPN or PyTorch?
- What Are the Differences Between Images and Backups?
- Can I Tailor an Image?
- How Do I Migrate an ECS to a Different Region of Another Account?
- How Can I Back Up the Current Status of an ECS for Restoration in the Case of a System Fault?
- How Can I Apply a Private Image to an Existing ECS?
- Can I Import Data from a Data Disk Image to a Data Disk?
- Can I Use Private Images of Other Accounts?
- End-of-Support for OSs
Image Creation
- General Creation FAQ
- Full-ECS Image FAQ
- How Can I Use a Backup to Create an EVS Disk or ECS?
- Is There Any Difference Between the Image Created from a CSBS/CBR Backup and That Created from an ECS?
- Why Can't I Find an ISO Image When I Want to Use It to Create an ECS or Change the OS of an ECS?
- How Do I Create a Full-ECS Image Using an ECS That Has a Spanned Volume?
- Why Is Sysprep Required for Creating a Private Image from a Windows ECS?
- How Do I Handle the Startup Failure of a Windows ECS Created from a Windows Image Generalized by Sysprep?
- What Do I Do If I Cannot Create an Image in ZVHD2 Format Using an API?
- Image Sharing
OS
- How Do I Select an OS?
- How Is BIOS Different from UEFI?
- What Do I Do If I Cannot Change the Resolution of a Windows OS Booted in UEFI Mode?
- How Do I Delete Redundant Network Connections from a Windows ECS?
- What Do I Do If an ECS Starts Slowly?
- What Do I Do If the One-Click Password Resetting Plug-In Failed to Start?
- Why Can't I Find My Private Image When I Want to Use It to Create an ECS or Change the OS of an ECS?
Image Import
- Can I Use Images in Formats not Described in This Document?
- What Are the Impacts If I Do Not Pre-configure an ECS Used to Create a Private Image?
- How Do I Import an OVF or OVA File to the Cloud Platform?
- What Do I Do If I Chose the Wrong OS or System Disk Capacity When Registering a Private Image?
- Why Did My VHD Upload Fail? Why Does the System Say the System Disk in the VHD Image File Is Larger Than What I Specified on the Management Console?
- How Do I Import Existing Huawei Cloud Private Images to a Specified Region?
Image Export
- Can I Download My Private Images to a Local PC?
- Can I Use the System Disk Image of an ECS on a BMS After I Export It from the Cloud Platform?
- Why Is the Image Size in an OBS Bucket Different from That Displayed in IMS?
- Can I Download a Public Image to My PC?
- What Are the Differences Between Import/Export and Fast Import/Export?
- Why the Export Option Is Unavailable for My Image?
Image Optimization
- Must I Install Guest OS Drivers on an ECS?
- Why Do I Need to Install and Update VirtIO Drivers for Windows?
- What Will the System Do to an Image File When I Use the File to Register a Private Image?
- How Do I Configure an ECS, a BMS, or an Image File Before I Use It to Create an Image?
- What Do I Do If a Windows Image File Is Not Pre-Configured When I Use It to Register a Private Image?
- What Do I Do If a Linux Image File Is Not Pre-Configured When I Use It to Register a Private Image?
- How Do I Optimize an Image?
- How Do I Use a Private Image Created from a First-Generation ECS to Create a Second-Generation ECS?
- How Do I Enable NIC Multi-Queue for an Image?
- How Do I Configure an ECS to Use DHCPv6?
- How Do I Make a System Disk Image Support Fast ECS Creation?
- Why Did I Fail to Install Guest OS Drivers on a Windows ECS?
- How Do I Install Native Xen and KVM Drivers?
- Image Replication
- Image Deletion
- Image Encryption
- KooGallery Images
- Accounts and Permissions
- Cloud-Init
ECS Creation
- Can I Change the Image of a Purchased ECS?
- Can I Change the Specifications Defined by a Private Image When I Use the Image to Create an ECS?
- Can I Specify the System Disk Capacity When I Create an ECS Using an Image?
- What Do I Do If a Partition Is Not Found During the Startup of an ECS Created from an Imported Private Image?
- What Do I Do If the Disks of a CentOS ECS Created from an Image Cannot Be Found?
- What Do I Do If I Enabled Automatic Configuration During Image Registration for an ECS Created from a Windows Image and Now It Won't Start?
- What Do I Do If an Exception Occurs When I Start an ECS Created from an Image Using UEFI Boot?
Driver Installation
- How Do I Install PV Drivers in Windows?
- How Do I Install VirtIO Drivers in Windows?
- How Do I Install Native KVM Drivers in Linux?
- Image Tags
- Billing
Image Consulting
- Videos
- Glossary
More Documents
- Overview
- Introduction
- Deleting Images
Sharing Images
- Overview
- Obtaining the Account Name and Project Name
- Encrypting Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
- Basic Concepts
Image Creation
- Image Sharing
- OS
Image Import
Image Export
Image Optimization
- How Do I Configure an ECS or an Image File Before I Use It to Create an Image?
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
- Billing
Image Consulting
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Querying Images (Native OpenStack API)
- Querying Image Details (Native OpenStack API)
- Updating Image Information (Native OpenStack API)
- Uploading an Image (Native OpenStack API)
- Deleting an Image (Native OpenStack API)
- Creating Image Metadata (Native OpenStack API)
- Deleting an Image (Native OpenStack API v1.1 - Abandoned and Not Recommended)
- Querying Image Metadata (Native OpenStack API v1 - Abandoned and Not Recommended)
- Querying Image Details (Native OpenStack API v1.1 - Abandoned and Not Recommended)
- Image Schema (Native OpenStack APIs)
- API Version Query (Native OpenStack API)
- Examples
- Permission Policies and Supported Actions
- Common Parameters
- Status Codes
- Error Codes
- Change History
User Guide (Paris Regions)
- Overview
- Introduction
- Deleting Images
- Sharing Images
- Encrypting Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
- Basic Concepts
Image Creation
- Image Sharing
OS
- What Do I Do If a Windows 7 ECS Equipped with an Intel 82599 NIC Reports an Error in SR-IOV Scenarios?
Image Import
Image Export
Image Optimization
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
Image Consulting
API Reference (Paris Regions)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Examples
- API Actions
- Common Parameters
- Status Codes
- Error Codes
- Change History
- Overview
- Introduction
- Deleting Images
Sharing Images
- Overview
- Encrypting Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
- Basic Concepts
Image Creation
- Image Sharing
- OS
Image Import
Image Export
Image Optimization
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
Image Consulting
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Examples
- Common Parameters
- Status Codes
- Error Codes
- Change History
User Guide (Ankara Region)
- Overview
- Introduction
- Deleting Images
- Sharing Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
Image Creation
- Image Sharing
OS
Image Import
Image Export
Image Optimization
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
Image Consulting
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Examples
- Common Parameters
- Status Codes
- Error Codes
- Change History
Preparing an Image File
You need to understand the constraints and known issues (see Known Issues) of your OS and prepare an image file that can be used to create a private image.
Currently, a large image file (maximum: 1 TB) can be imported only in RAW or ZVHD2 format. In addition to the requirements described in Table 2, a bitmap file needs to be generated alongside each RAW image file. The bitmap file is uploaded together with the image file. For details, see Fast Import of an Image File.
Initial Configuration for an Image File
The initial configuration must be completed on the source VM before an image file is exported from it. If you did not configure it, use the image file to create an ECS, configure the ECS, and use the ECS to create a private image. For details, see What Do I Do If a Linux Image File Is Not Pre-Configured When I Use It to Register a Private Image?
Configuration Item |
How to Configure |
Network |
DHCP must be configured. Otherwise, the ECS startup or network capability will be abnormal. For details, see: The following value-added operations are optional:
Tools |
You are advised to install Cloud-Init. Cloud-Init is an open-source tool for cloud instance initialization. When creating ECSs from an image with Cloud-Init, you can use user data injection to customize initialization details (for example, an ECS login password) to the ECSs. You can also configure and manage a running ECS by querying and using metadata. If Cloud-Init is not installed, you cannot apply these custom configurations to your ECSs, and you will have to use the original password in the image file to log in to the ECSs. For details, see Installing Cloud-Init. |
Plug-ins |
You are advised to install the password reset plug-in CloudResetPwdAgent before creating a private image. In this way, you can reset the password of ECSs created from the image by a few clicks. For details, see Installing the One-Click Password Reset Plug-In. |
Drivers |
File system |
Data disks |
If multiple data disks are attached to the ECS used to create a private image, ECSs created from the image may be unavailable. Therefore, you need to detach all data disks from the ECS before using it to create a private image. For details, see Detaching Data Disks from an ECS. |
Image File Properties
Image File Property |
Requirement |
OS |
For details about the supported OS versions, see External Image File Formats and Supported OSs. These OSs support automatic configuration. For details, see What Will the System Do to an Image File When I Use the File to Register a Private Image? For other OSs, check and install VirtIO drivers (see Installing Native KVM Drivers). On the image registration page, select Other Linux. After the image is imported, whether the system is started depends on the driver integrity. |
Image format |
VMDK, VHD, QCOW2, RAW, VHDX, QED, VDI, QCOW, ZVHD2, and ZVHD |
Image size |
Maximum file size: 128 GB
If the image size is between 128 GB and 1 TB, convert the image file into RAW or ZVHD2 and import it using fast import.
Other
- Currently, images with data disks cannot be created. The image file must contain only a system disk, and the system disk size must be [40 GB, 1024 GB].
- The initial password in the image file must contain uppercase letters, lowercase letters, digits, and special characters (!@$%^-_=+[{}]:,./?).
- The boot partition and system partition must be on the same disk.
- Supported boot modes:
Some x86 OS images support the UEFI boot mode. (For details, see OSs Supporting UEFI Boot Mode.)
Arm OS images support only the UEFI boot mode.
- The image file cannot be encrypted, or ECSs created from the registered image may not work properly.
- The /etc/fstab file cannot contain automatic mounting information of non-system disks. Otherwise, the login to the created ECS may fail.
- If the external image file uses LVM as the system disk, ECSs created from the private image do not support file injection.
- If the VM where the external image file is located has been shut down, it must be a graceful shutdown. Otherwise, a blue screen may occur when the ECS created from the private image is started.
- A VMDK image file must be created from a VM generated by VMware Tools. Otherwise, the system may fail to start due to image parsing problems.
