- What's New
- Function Overview
- Getting Started
User Guide
- Using IAM to Grant Access to IMS
Creating a Private Image
- Introduction
- Creating a System Disk Image from a Windows ECS
- Creating a System Disk Image from a Linux ECS
- Creating a Windows System Disk Image from an External Image File
- Creating a Linux System Disk Image from an External Image File
- Creating a BMS System Disk Image
- Creating a Data Disk Image from an ECS
- Creating a Data Disk Image from an External Image File
- Creating a Full-ECS Image from an ECS
- Creating a Full-ECS Image from a CSBS Backup
- Creating a Full-ECS Image from a CBR Backup
- Creating a Windows System Disk Image from an ISO File
- Creating a Linux System Disk Image from an ISO File
- Importing an Image
- Fast Import of an Image File
Managing Private Images
- Creating an ECS from an Image
- Modifying an Image
- Exporting an Image
- Exporting Image List
- Checking the Disk Capacity of an Image
- Deleting Images
Sharing Images
- Overview
- Obtaining the Project ID, Account ID, and Organization URN
- Sharing Specified Images
- Accepting or Rejecting Shared Images
- Rejecting Accepted Images
- Accepting Rejected Images
- Stopping Sharing Images
- Adding Tenants Who Can Use Shared Images
- Deleting Image Recipients Who Can Use Shared Images
- Replicating a Shared Image
- Replicating Images Within a Region
- Replicating Images Across Regions
- Optimizing a Windows Private Image
Optimizing a Linux Private Image
- Optimization Process
- Checking Whether a Private Image Needs to be Optimized
- Using a Script to Optimize a Xen Private Image
- Uninstalling PV Drivers from a Linux ECS
- Changing Disk Identifiers in the GRUB File to UUID
- Changing Disk Identifiers in the fstab File to UUID
- Installing Native Xen and KVM Drivers
- Installing Native KVM Drivers
- Clearing System Logs
- Encrypting Images
- Windows Operations
- Linux Operations
- Managing Public Images
- Managing Tags
- Managing Quotas
- Auditing Key Operations
Best Practices
- Overview
- Creating a Windows Image Using VirtualBox and an ISO File
- Creating a Linux Image Using VirtualBox and an ISO File
- Cleaning Up the Disk Space of a Windows ECS
- Converting the Image Format
- Creating a Private Image Using Packer
- Configuring an ISO File as a Local Image Source
- Migrating ECSs Across Accounts and Regions
- Migrating Service Data Across Accounts (Data Disks)
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Native OpenStack APIs
- Examples
- Common Parameters
Historical APIs
Image (Native OpenStack APIs)
- Querying Images (Native OpenStack API V2, Discarded)
- Querying Image Details (Native OpenStack API V2, Discarded)
- Modifying an Image (Native OpenStack API V2, Discarded)
- Uploading an Image (Native OpenStack API V2, Discarded)
- Deleting an Image (Native OpenStack API V1.1, Discarded)
- Querying Image Metadata (Native OpenStack API V1, Discarded)
- Querying Image Details (Native OpenStack API V1.1, Discarded)
- Image Tagging (Native OpenStack APIs)
- Image Sharing (Native OpenStack APIs)
- Status Codes
- Error Codes
- SDK Reference
Image Consulting
- How Do I Select an Image?
- What Do I Do If I Cannot Find a Desired Image?
- Are There Any Public Images Already Containing Certain Applications, Such as OpenVPN or PyTorch?
- What Are the Differences Between Images and Backups?
- Can I Tailor an Image?
- How Do I Migrate an ECS to a Different Region of Another Account?
- How Can I Back Up the Current Status of an ECS for Restoration in the Case of a System Fault?
- How Can I Apply a Private Image to an Existing ECS?
- Can I Import Data from a Data Disk Image to a Data Disk?
- Can I Use Private Images of Other Accounts?
- End-of-Support for OSs
Image Creation
- General Creation FAQ
- Full-ECS Image FAQ
- How Can I Use a Backup to Create an EVS Disk or ECS?
- Is There Any Difference Between the Image Created from a CSBS/CBR Backup and That Created from an ECS?
- Why Can't I Find an ISO Image When I Want to Use It to Create an ECS or Change the OS of an ECS?
- How Do I Create a Full-ECS Image Using an ECS That Has a Spanned Volume?
- Why Is Sysprep Required for Creating a Private Image from a Windows ECS?
- How Do I Handle the Startup Failure of a Windows ECS Created from a Windows Image Generalized by Sysprep?
- What Do I Do If I Cannot Create an Image in ZVHD2 Format Using an API?
- Image Sharing
OS
- How Do I Select an OS?
- How Is BIOS Different from UEFI?
- What Do I Do If I Cannot Change the Resolution of a Windows OS Booted in UEFI Mode?
- How Do I Delete Redundant Network Connections from a Windows ECS?
- What Do I Do If an ECS Starts Slowly?
- What Do I Do If the One-Click Password Resetting Plug-In Failed to Start?
- Why Can't I Find My Private Image When I Want to Use It to Create an ECS or Change the OS of an ECS?
Image Import
- Can I Use Images in Formats not Described in This Document?
- What Are the Impacts If I Do Not Pre-configure an ECS Used to Create a Private Image?
- How Do I Import an OVF or OVA File to the Cloud Platform?
- What Do I Do If I Chose the Wrong OS or System Disk Capacity When Registering a Private Image?
- Why Did My VHD Upload Fail? Why Does the System Say the System Disk in the VHD Image File Is Larger Than What I Specified on the Management Console?
- How Do I Import Existing Huawei Cloud Private Images to a Specified Region?
Image Export
- Can I Download My Private Images to a Local PC?
- Can I Use the System Disk Image of an ECS on a BMS After I Export It from the Cloud Platform?
- Why Is the Image Size in an OBS Bucket Different from That Displayed in IMS?
- Can I Download a Public Image to My PC?
- What Are the Differences Between Import/Export and Fast Import/Export?
- Why the Export Option Is Unavailable for My Image?
Image Optimization
- Must I Install Guest OS Drivers on an ECS?
- Why Do I Need to Install and Update VirtIO Drivers for Windows?
- What Will the System Do to an Image File When I Use the File to Register a Private Image?
- How Do I Configure an ECS, a BMS, or an Image File Before I Use It to Create an Image?
- What Do I Do If a Windows Image File Is Not Pre-Configured When I Use It to Register a Private Image?
- What Do I Do If a Linux Image File Is Not Pre-Configured When I Use It to Register a Private Image?
- How Do I Optimize an Image?
- How Do I Use a Private Image Created from a First-Generation ECS to Create a Second-Generation ECS?
- How Do I Enable NIC Multi-Queue for an Image?
- How Do I Configure an ECS to Use DHCPv6?
- How Do I Make a System Disk Image Support Fast ECS Creation?
- Why Did I Fail to Install Guest OS Drivers on a Windows ECS?
- How Do I Install Native Xen and KVM Drivers?
- Image Replication
- Image Deletion
- Image Encryption
- KooGallery Images
- Accounts and Permissions
- Cloud-Init
ECS Creation
- Can I Change the Image of a Purchased ECS?
- Can I Change the Specifications Defined by a Private Image When I Use the Image to Create an ECS?
- Can I Specify the System Disk Capacity When I Create an ECS Using an Image?
- What Do I Do If a Partition Is Not Found During the Startup of an ECS Created from an Imported Private Image?
- What Do I Do If the Disks of a CentOS ECS Created from an Image Cannot Be Found?
- What Do I Do If I Enabled Automatic Configuration During Image Registration for an ECS Created from a Windows Image and Now It Won't Start?
- What Do I Do If an Exception Occurs When I Start an ECS Created from an Image Using UEFI Boot?
Driver Installation
- How Do I Install PV Drivers in Windows?
- How Do I Install VirtIO Drivers in Windows?
- How Do I Install Native KVM Drivers in Linux?
- Image Tags
- Billing
Image Consulting
- Videos
- Glossary
More Documents
- Overview
- Introduction
- Deleting Images
Sharing Images
- Overview
- Obtaining the Account Name and Project Name
- Encrypting Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
- Basic Concepts
Image Creation
- Image Sharing
- OS
Image Import
Image Export
Image Optimization
- How Do I Configure an ECS or an Image File Before I Use It to Create an Image?
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
- Billing
Image Consulting
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Querying Images (Native OpenStack API)
- Querying Image Details (Native OpenStack API)
- Updating Image Information (Native OpenStack API)
- Uploading an Image (Native OpenStack API)
- Deleting an Image (Native OpenStack API)
- Creating Image Metadata (Native OpenStack API)
- Deleting an Image (Native OpenStack API v1.1 - Abandoned and Not Recommended)
- Querying Image Metadata (Native OpenStack API v1 - Abandoned and Not Recommended)
- Querying Image Details (Native OpenStack API v1.1 - Abandoned and Not Recommended)
- Image Schema (Native OpenStack APIs)
- API Version Query (Native OpenStack API)
- Examples
- Permission Policies and Supported Actions
- Common Parameters
- Status Codes
- Error Codes
- Change History
User Guide (Paris Regions)
- Overview
- Introduction
- Deleting Images
- Sharing Images
- Encrypting Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
- Basic Concepts
Image Creation
- Image Sharing
OS
- What Do I Do If a Windows 7 ECS Equipped with an Intel 82599 NIC Reports an Error in SR-IOV Scenarios?
Image Import
Image Export
Image Optimization
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
Image Consulting
API Reference (Paris Regions)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Examples
- API Actions
- Common Parameters
- Status Codes
- Error Codes
- Change History
- Overview
- Introduction
- Deleting Images
Sharing Images
- Overview
- Encrypting Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
- Basic Concepts
Image Creation
- Image Sharing
- OS
Image Import
Image Export
Image Optimization
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
Image Consulting
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Examples
- Common Parameters
- Status Codes
- Error Codes
- Change History
User Guide (Ankara Region)
- Overview
- Introduction
- Deleting Images
- Sharing Images
- Linux Operations
- Managing Tags
- Managing Quotas
Image Consulting
Image Creation
- Image Sharing
OS
Image Import
Image Export
Image Optimization
- Image Replication
- Image Deletion
- Image Encryption
- Cloud-Init
ECS Creation
Driver Installation
- Image Tags
Image Consulting
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- IMS APIs
- Examples
- Common Parameters
- Status Codes
- Error Codes
- Change History
If you have created and configured a Linux ECS based on your service requirements (for example, by installing software and setting up an application environment), you can create a system disk image based on this configured ECS. Then, all new ECSs created from this image will have the same software and environment preinstalled.
Creating a system disk image does not affect the running of services on the ECS or cause data loss.
Background
The following figure shows the process of creating a system disk image from an ECS.
- System disk images are often used for application scale-out. They can also be used for hybrid cloud deployment. You can create system disk images for resource synchronization on and off cloud. The procedure is as follows:
- Create a system disk image from an ECS.
If the ECS is created from any of the following images, the system disk image cannot be exported:- ISO image
- Private image created from a SUSE, Red Hat, Ubuntu, or Oracle Linux public image
- Private image created from a KooGallery image
- Export the image to an OBS bucket. For details, see Exporting an Image.
- Download the image file from the OBS bucket.
- You can create an image from a running ECS.
The image creation does not affect service running on the ECS.
In this process, do not stop, start, or restart the ECS, or the image creation may fail.
- The time required for creating an image depends on the ECS system disk size, network quality, and the number of concurrent tasks.
- A system disk image will be created in the same region as the ECS that was used to create it. For example, if an ECS is located in the CN-Hong Kong region, the system disk image created from that ECS will also be located in the CN-Hong Kong region. If you want to use the image in another region, you must first replicate it to that region. For details, see Replicating Images Across Regions.
- If an ECS has expired or been released, you can use the system disk image created from the ECS to restore it.
Before creating a private image from an ECS:
- Delete any sensitive data the ECS may contain.
- Ensure that the ECS is in the Running or Stopped state.
- Check network configuration of the ECS and ensure that DHCP is configured for the NICs. For details, see Configuring DHCP.
- Check whether the one-click password reset plug-in has been installed on the ECS. The password reset function on the management console is only available for new ECSs that have this plug-in installed. For details, see Installing the One-Click Password Reset Plug-In.
- Check whether Cloud-Init has been installed on the ECS. The user data injection function on the management console is only available for new ECSs that have this tool installed. You can use data injection, for example, to set the login password for a new ECS. For details, see Installing Cloud-Init and Configuring Cloud-Init.
- Delete any network rules to prevent NIC name drift on the ECSs created from the image. For details, see Deleting Files from the Network Rule Directory.
- To ensure that the ECSs created from the image support both Xen and KVM virtualization, the Linux ECS used to create the image has to be modified. For instance, disk identifiers in the GRUB and fstab files need to be UUID and native Xen and KVM drivers need to be installed.
For details, see steps 2 to 6 in Optimization Process.
- If multiple data disks are attached to an ECS used to create a private image, the ECSs created from the image may be unavailable. You need to detach all data disks from the ECS before using it to create an image. For details, see Detaching Data Disks from an ECS.
- If data disks have been attached to the ECS and automatic partition mounting has been configured in the fstab file for the ECS, delete these configurations from the file before using the ECS to create a system disk image.
- Ensure that the system disk capacity of the ECS used to create a system disk image must be no greater than 1 TB.
If the capacity is greater than 1 TB, you can only use it to create a full-ECS image.
If an ECS is created from a public image, the one-click password reset plug-in and Cloud-Init have been installed by default. You can follow the guide to verify the installation.
- Access the IMS console.
- Under Compute, click Image Management Service.
The IMS console is displayed.
- Create a system disk image.
- Click Create Image in the upper right corner.
- Set image parameters.
Table 1 and Table 2 list the parameters in the Image Type and Source and Image Information areas, respectively.
Table 1 Image type and source Parameter
Type
Select Create Image.
Region
Select a region close to where your services will be provided.
If you select an incorrect region here, you can replicate the created image to your desired region later. For details, see Replicating an Image Across Regions.
Image Type
Select System disk image.
Source
Select ECS and select an ECS with required configurations.
Table 2 Image information Parameter
Encryption
This parameter specifies whether the image will be encrypted. The value is provided by the system and cannot be changed.
- Only an unencrypted private image can be created from an unencrypted ECS.
- Only an encrypted private image can be created from an encrypted ECS.
Name
Set a name for the image.
Enterprise Project
Select an enterprise project from the drop-down list. This parameter is available only if you have enabled enterprise projects or your account is an enterprise account. To enable this function, contact your customer manager.
An enterprise project provides central management of cloud resources on a project.
Tag
(Optional) Set a tag key and a tag value for the image to make identification and management of your images easier.
If your organization has configured tag policies for images, you need to add tags to your images based on the policies. If you add a tag that does not comply with the tag policies, images may fail to be created. Contact the organization administrator to learn more about the tag policies.
- Each tag consists of a key and a value. The key contains a maximum of 36 characters, and the value contains a maximum of 43 characters. The key cannot be left blank or an empty string. The value cannot be left blank but can be an empty string.
- An image can have a maximum of 10 tags.
(Optional) Enter a description of the image.
- Read and agree to the disclaimer, and click Next.
- Confirm the settings and click Submit.
- Go back to the Private Images page and view the new system disk image.
The time required for creating an image depends on the ECS system disk size, network quality, and the number of concurrent tasks. When the image status changes to Normal, the image creation is complete.
- Do not perform any operations on the selected ECS or its associated resources during image creation.
- An ECS created from an encrypted image is also encrypted. The key used for encrypting the ECS is the same as that used for encrypting the image.
- An image created from an encrypted ECS is also encrypted. The key used for encrypting the image is the same as that used for encrypting the ECS.
Follow-up Procedure
After a system disk image is created, you can:
- Use the image to create new ECSs. For details, see Creating an ECS from an Image.
- Use the image to change the OSs of existing ECSs. For details, see Changing the OS.
