Viewing Tracing Logs
After you enable CTS, the system starts recording operations performed on IEF resources. CTS stores operation records generated within a week.
This section describes how to view the records on the CTS console.
- Log in to the CTS console.
- In the navigation pane, choose Trace List.
- Set the filter criteria and click Query.
The following filters are available:
- Trace Source, Resource Type, and Search By
Select the desired filter criteria from the drop-down lists. Select Management for Trace Type and IEF for Trace Source.
In the preceding information:
- If you select Resource ID for Search By, you need to enter a resource ID. Only whole word match is supported.
- If you select Resource name for Search By, you need to select or enter a specific resource name.
- Operator: Select a specific operator from the drop-down list.
- Trace Status: Select one of All trace statuses, Normal, Warning, and Incident.
- Time range: You can select Last 1 hour, Last 1 day, Last 1 week, or Customize.
- Click
on the left of a trace to expand its details. - Click View Trace in the upper right corner of the trace details area.
