IEF Operations Supported by CTS
Cloud Trace Service (CTS) is a log audit service provided by HUAWEI CLOUD and intended for cloud security. It allows you to collect, store, and query cloud resource operation records and use these records for security analysis, compliance auditing, resource tracking, and fault locating.
With CTS, you can record operations associated with IEF for future query, audit, and backtrack operations.
Key Operations Recorded by CTS
Operation |
Resource Type |
Trace Name |
Registering an edge node |
node |
createEdgeNode |
Updating an edge node |
node |
updateEdgeNode |
Deleting an edge node |
node |
deleteEdgeNode |
Creating an edge node group |
group |
createEdgeGroup |
Updating an edge node group |
group |
updateEdgeGroup |
Deleting an edge node group |
group |
deleteEdgeGroup |
Creating a device template |
deviceTemplate |
createDeviceTemplate |
Updating a device template |
deviceTemplate |
updateDeviceTemplate |
Deleting a device template |
deviceTemplate |
deleteDeviceTemplate |
Registering a device |
device |
createDevice |
Updating a device |
device |
updateDevice |
Deleting a device |
device |
deleteDevice |
Deploying an Edge-Connector application |
device |
deployConnector |
Updating device twins |
device |
updateDeviceTwin |
Updating the device access configuration |
device |
updateDeviceAccessConfig |
Creating an application template |
application |
createApplication |
Updating an application template |
application |
updateApplication |
Deleting an application template |
application |
deleteApplication |
Creating an application template version |
appVersion |
createAppVersion |
Updating an application template version |
appVersion |
updateAppVersion |
Deleting an application template version |
appVersion |
deleteAppVersion |
Creating a ConfigMap |
configmap |
createConfigMap |
Updating a ConfigMap |
configmap |
updateConfigMap |
Deleting a ConfigMap |
configmap |
deleteConfigMap |
Creating a containerized application |
deployment |
createDeployment |
Updating a containerized application |
deployment |
updateDeployment |
Deleting a containerized application |
deployment |
deleteDeployment |
Querying a list of containerized applications |
deployment |
getDeploymentList |
Querying a containerized application |
deployment |
getDeployment |
Creating an endpoint |
endpoint |
createEndpoint |
Deleting an endpoint |
endpoint |
deleteEndpoint |
Adding a node certificate |
node |
AddNodeCert |
Deleting a node certificate |
node |
deleteNodeCert |
Upgrading the firmware |
nodeFirmware |
UpgradeNodeFirmware |
Querying a list of application instances |
Pods |
getPods |
Querying an instance |
Pod |
getPod |
Creating a node registration job |
product |
createProduct |
Deleting a node registration job |
product |
deleteProduct |
Creating a node upgrade job/Creating an application deployment job/Creating an application upgrade job |
batchJob |
createJob |
Stopping a node upgrade job/Stopping an application deployment job/Stopping an application upgrade job |
batchJob |
pauseJob |
Deleting a node upgrade job/Deleting an application deployment job/Deleting an application upgrade job |
batchJob |
deleteJob |
Restoring a node upgrade job/Restoring an application deployment job/Restoring an application upgrade job |
batchJob |
restoreJob |
Retrying a node upgrade job/Retrying an application deployment job/Retrying an application upgrade job |
batchJob |
retryJob |
Querying quotas |
quota |
getQuota |
Updating a quota |
quota |
updateQuota |
Creating a rule |
rule |
createRule |
Deleting a rule |
rule |
deleteRule |
Updating a rule |
rule |
updateRule |
Creating a secret |
secret |
createSecret |
Updating a secret |
secret |
updateSecret |
Deleting a secret |
secret |
deleteSecret |
Filtering resources by tag |
Tags |
filterTags |
Adding or deleting tags in batches |
Tags |
batchAddDeleteTags |
Adding a tag |
Tags |
addTag |
Deleting a tag |
Tags |
deleteTag |
Binding encryption data |
encryptdata |
bindEncryptdata |
Creating encryption data |
encryptdata |
createEncryptData |
Deleting encryption data |
encryptdata |
deleteEncryptData |
Unbinding encryption data |
encryptdata |
unbindEncryptdata |
Updating encryption data |
encryptdata |
updateEncryptData |
Creating a gateway |
gateway |
createGateway |
Creating a virtual service |
gateway |
createVirtualService |
Deleting a gateway |
gateway |
deleteGateway |
Deleting a virtual service |
gateway |
deleteVirtualService |
Updating a gateway |
gateway |
updateGateway |
Updating a virtual service |
gateway |
updateVirtualService |
Creating a system subscription |
Systemevent |
createSystemevent |
Deleting a system subscription |
Systemevent |
DeleteSystemevent |
Enabling a system subscription |
Systemevent |
startSystemevent |
Disabling a system subscription |
Systemevent |
stopSystemevent |
