Alarm Reporting
Updated on 2022-08-11 GMT+08:00
This topic is used to report alarms to AOM.
Topic
$hw/alarm/{appname}/add
Type
appname
String
Application name, which is user-defined.
Usage
Use an MQTT client to publish this topic.
Parameter Description
Type
alarmName
String
Alarm name.
alarmId
String
Alarm ID, which must be unique. For details, see Generating an alarmId.
detailedInformation
String
Alarm description.
url
String
URL for root cause analysis. If the URL is not available, leave this field blank.
source
String
Alarm source. The value is a character string consisting of uppercase and lowercase letters.
cleared
Boolean
Whether the alarm is cleared.
  • true: The alarm has been cleared.
  • false: The alarm needs to be cleared manually.
policyID
String
ID of an alarm rule. For a threshold rule, set this parameter to ruleId. If no threshold rule is configured, leave this field blank.
objectInstance
String
Location information. If this field is not specified, the value of this parameter is the same as that of alarmId by default.
perceivedSeverity
Integer
Alarm severity.
  • 1: Critical
  • 2: Major
  • 3: Minor
  • 4: Warning
resourceId
Object
Alarm information. For details, see Table 1.
neType
String
Type of the resource for which the alarm is generated.
  • Application
  • DB
  • Host
eventType
Integer
Alarm type.
  • 21: dynamic threshold alarm
  • 22: batch threshold alarm
  • 23: threshold alarm
  • 24: system alarm
  • 25: probe added or deleted
  • 26: Agent installation alarm
  • 27: Quota threshold-crossing alarm
probableCause
String
Possible causes.
proposedRepairActions
String
Handling suggestions.
Table 1 resourceId
Type
namespace
String
Resource type. The options are as follows:
  • PAAS.CONTAINER: container metrics
  • PAAS.NODE: node metrics
dimension
Object
Dimension information, which is associated with the node application information reported by the monitoring module. For details, see Table 2.
Currently, alarms are about nodes and applications. Therefore, you only need to pay attention to these two dimensions.
The application dimension covers service, instance, container, and process information. You can select one or more types of information to be reported.
  • Service information: clusterId, nameSpace, and serviceID
  • Instance information: podID and podName
  • Container information: containerID and containerName
  • Process information: processID and processName
Table 2 Dimension
Type
clusterId
String
Project ID. For details on how to obtain a project ID, see Obtaining a Project ID.
nameSpace
String
The default value is default.
nodeIP
String
Node IP address.
serviceID
String
Service ID.
  • For applications, the value is the MD5 value of {projectId}_{hostid}_{appName}.
  • For processes, the value is the MD5 value of {projectId}_{hostid}_{Process name}_{Process pid}.
  • processID can be calculated as follows: md5({projectId})_{hostid}_md5({Process name}) _{process pid}.
    md5(projectId) indicates the MD5 value of projectId, and md5({Process name}) indicates the MD5 value of the process name.
The dimension settings must be consistent with those reported by the monitoring module. Otherwise, the corresponding resources cannot be associated.
podID
String
Instance ID.
podName
String
Instance name.
containerID
String
Container ID.
containerName
String
Container name.
processID
String
Process ID.
processName
String
Process name.
Application
String
Application name.
You do not need to use this method to generate the alarmId. However, you need to ensure that the alarmId is unique.
Generate the MD5 value of {projectId}_{Service name for which the alarm is generated}_{Dimension information}_{Metric name}_{Alarm type}_{Rule information}.
Where:
  • projectId: Project ID. For details on how to obtain a project ID, see Obtaining a Project ID.
  • Dimension information:
    • Node information: {clusterId}_{namespace}_{ip}
    • Container information: {clusterId}_{namespace}_{appName}_{podName}_{containerId}
    • Application information: {clusterId}_{namespace}_{appName}
  • Alarm type:
    • 24: system alarm
  • Rule information: Set this field to a rule name for threshold alarms and to NA for alarms generated by the service itself. For dynamic threshold alarms, set this field to policyId.
Example
  • Node alarm
       "alarmName": "test",
        "alarmId": "73ccbccce05de74f9d3dda42f6ecfe20",
        "detailedInformation": "test",
        "url": "",
        "source": "IEF",
        "cleared": false,
        "policyID": "",
        "perceivedSeverity": 4,
        "resourceId": {
            "namespace": "PAAS.NODE",
            "dimension": {
                "clusterId": "e277befa37a64ed1aa25b522e686bc28",
                "nameSpace": "default",
                "nodeIP": "192.168.0.164"
        "neType": "Host",
        "eventType": 23
  • Application alarm:
        "alarmName": "Application restart",
        "alarmId": "b09076ff565c59d4da0db0c9223781",
        "detailedInformation": "Application restart test",
        "url": "",
        "source": "IEF",
        "cleared": false,
        "policyID": "",
        "perceivedSeverity": 3,
        "resourceId": {
            "namespace": "PAAS.CONTAINER",
            "dimension": {
                "containerName": "container-e991acd3-864c-4038-8a90-e042eebab496",
                "containerID": "70b385315c8ac507b3de7dfe1258932cea0b53a850b7d030ce7ed0a55c47877c",
                "podID": "0e9ce4fd-b732-11e9-8a30-fa163e9b3546",
                "podName": "hxkapp1-7898f5bd4b-2lj8z"
        "neType": "Application",
        "eventType": 23
