Device Member Update
This topic is used to subscribe to updates on bindings between end devices and edge nodes.
Topic
$hw/events/node/{node_id}/membership/updated
Parameter |
Type |
Description |
node_id |
String |
Node ID. |
Usage
Use an MQTT client to subscribe to this topic.
Parameter Description
Parameter |
Type |
Description |
event_id |
String |
Event ID. |
timestamp |
Int64 |
Timestamp when the event occurred. |
added_devices |
Array |
Information about end devices, including the device ID, name, properties, and twin properties. |
removed_devices |
Array |
Example
When an end device is bound to an edge node, the following message is received:
"event_id":"04a975ab-fd51-49be-85f5-5967e994f640",
"timestamp":1557314742136,
"added_devices":[
"id":"ab39361a-6fc0-4c94-b919-72b1e08ca690",
"name":"IEF-device",
"state":"unknown",
"attributes":{
"address":{
"value":"xxx",
"optional":true,
"metadata":{
"type":"string"
"twin":{
"state":{
"expected":{
"value":"running",
"metadata":{
"timestamp":1557314434570
"optional":true,
"metadata":{
"type":"string"
"removed_devices":null
