- What's New
- Product Bulletin
- Getting Started
User Guide
- Edge Computing with IEF
- Service Instances
User Guide (Professional)
- Node Management
End Device Management
- End Devices and Device Twins
- Device Templates
- End Devices
- Binding an End Device to an Edge Node
- Device Twin Working Principles
- Migrating Device Data to the Cloud
- Performing Security Authentication Using Certificate
MQTT Topics
- Device Twin Update
- Device Twin Delta
- Device Member Update
- Device Property Update
- Device Member Acquisition
- Device Member Acquisition Result
- Device Twin Acquisition
- Device Twin Acquisition Result
- Device Twin Modification
- Device Twin Modification Result
- Encryption Data Request
- Encryption Data Acquisition
- Alarm Reporting
- Alarm Clearance
- Custom Topics
- Containerized Application Management
- Edge-Cloud Messages
- Batch Management
- Auditing
- Permissions Management
User Guide (Platinum)
- Node Management
- Device Templates
- End Devices
MQTT Topics
- Device Twin Delta
- Alarm Reporting
- Alarm Clearance
- Custom Topics
- Application Mesh
- Batch Management
- Auditing
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
Edge Node Management
- Registering an Edge Node
- Updating an Edge Node
- Querying Details About an Edge Node
- Querying a List of Edge Nodes
- Deleting an Edge Node
- Starting or Stopping an Edge Node
- Updating End Devices for an Edge Node
- Querying Node Certificates
- Creating a Node Certificate
- Deleting a Node Certificate
- Performing an Edge Node Upgrade Check
- Upgrading Edge Nodes
- End Device Management
- End Device Template Management
Application Template Management
- Creating an Application Template
- Updating an Application Template
- Querying Details About an Application Template
- Querying a List of Application Templates
- Deleting an Application Template
- Creating an Application Template Version
- Updating an Application Template Version
- Querying Details About an Application Template Version
- Querying a List of Application Template Versions
- Deleting an Application Version
- Deployment Management
- Tag Management
- ConfigMap Management
- Secret Management
- Endpoint Management
- Rule Management
- System Subscription Event Management
- Batch Node Management
- Batch Job Management
- Quota Management
- Service Management
- Data Structure
- Appendix
- Change History
- SDK Reference
Edge Node FAQs
- What Do I Do If an Edge Node Is Faulty?
- What Are the Fault Scenarios of Edge Nodes?
- What Do I Do If Edge Node Management Fails?
- How Do I Obtain the Latest Device Properties After Device Properties Are Updated?
- What Operations Can I Perform After a Device Is Associated with a Node?
- Does an Edge Node Support Multiple GPUs?
- Can I Change the GPU on a Running Edge Node?
- How Is Edge Environment Security Protected?
- Why Cannot I View Monitoring Data on an Edge Node?
- How Can I Restore a Deleted Edge Node?
- What Is the Impact of IP Address Changing on an Edge Node?
- What Do I Do If the NTP Configuration Cannot Be Modified?
- How Do I Synchronize Time with the NTP Server?
- How Do I Obtain the IP Addresses of IEF Cloud Services?
- What Do I Do If the Edge Node Space Is Insufficient?
- How Do I Set Docker Cgroup Driver After Installing Docker on an Edge Node?
Edge Application FAQs
- What Do I Do If an Application Fails to Be Delivered to an Edge Node?
- What Do I Do If a Containerized Application Fails to Be Started on an Edge Node?
- What Do I Do If a Containerized Application Fails to Be Upgraded?
- What Do I Do If a Container Image Fails to Be Pulled?
- Why Cannot I View Application Logs and System Logs?
- How Do Applications Schedule GPU Resources?
- How Do I Control the Disk Space Occupied by a Container Engine?
- What Do I Do If a Containerized Application Cannot Access External IP Addresses
- What Do I Do If the Ascend AI Accelerator Card (NPU) Is Abnormal?
Edge-Cloud Message FAQs
- What Is Route Management?
- What Is a Message Endpoint in Route Management?
- What Is a Route?
- Why Does a Route Fail to Be Created?
- What Can I Do If a Message Fails to Be Forwarded over a Route?
- What Is the Impact of Disabling a Route?
- What Can I Do If SystemEventBus (MQTT Broker) of an Edge Node Fails to Be Connected?
- Network Management FAQs
- Basic Concept FAQs
- Region and AZ
- What Are the Specifications of Edge Nodes Supported by IEF?
- What Are the Differences Between Device Properties and Device Twins?
- What Programming Language Is Required for IEF Development?
- Do I Need to Prepare Edge Nodes by Myself?
- Can I Still Use the Previously Delivered Applications After My Account Is in Arrears?
- What Are the Differences Between IEF and IoT Edge?
- What Do I Do If an Agency Fails to Be Automatically Created?
- How Can I Deal With Insufficient Permissions?
- How Will the Multi-AZ Reconstruction of SWR Application Container Image Data Affect IEF?
Edge Node FAQs
Edgectl User Guide
- Overview
- Installing edgectl
- Example: Using edgectl to Run Commands
edgectl Commands
- Querying the edgectl Version
- Managing the Product Lifecycle
Checking an Item
- Checking the Hardware Architecture
- Checking the CPU
- Checking the Memory
- Checking Hard Disks
- Checking the Domain Name Resolution Function
- Checking Docker
- Checking Network Connectivity
- Checking the Installation Status of the IEF Software
- Checking the Running Status of the IEF Software
- Checking GPUs
- Checking NPUs
- Checking Processes
Error Codes
- Error Code Overview
- Common Errors
- Permission Errors
OS Errors
- ERROR3001 Failed to obtain the hardware architecture
- ERROR3002 Unsupported hardware architecture
- ERROR3101 Failed to obtain the CPU information of the node
- ERROR3102 Failed to obtain the real-time CPU status of the node
- ERROR3103 Insufficient node CPU
- ERROR3201 Failed to obtain the memory information of the node
- ERROR3202 Insufficient node memory
- ERROR3301 Failed to obtain the disk information of the node
- ERROR3302 Insufficient disk space on the node
- ERROR3401 Failed to resolve the domain name
- ERROR3501 Failed to check the network
- ERROR3601 Failed to obtain the process information of the node
- ERROR3602 Failed to obtain the total number of processes on the node
- ERROR3603 Number of remaining processes on the node is insufficient
IEF Software Errors
- ERROR5001 Incomplete IEF software installation
- ERROR5002 IEF software is not completely running
- ERROR5003 Failed to read the IEF software configuration file
- ERROR5004 Docker is not enabled for the IEF software
- ERROR5005 Failed to start the IEF software
- ERROR5006 Failed to stop the IEF software
- ERROR5101 No application data found
- ERROR5102 No status data of the application found
- ERROR5103 Container is not started
- ERROR5104 Container exits abnormally
- ERROR5105 Failed to pull the container image
- ERROR5106 Container exits
- Third-Party Dependency Errors
- Data Collection Errors
- Internal Errors
- Videos
Device Twin Delta
This topic is used to subscribe to device twin delta events. When a device twin changes, the twin properties whose actual values are different from expected values are returned.
Topic
$hw/events/device/{device_id}/twin/update/delta
Parameter |
Type |
Description |
device_id |
String |
End device ID. |
Usage
Use an MQTT client to subscribe to this topic.
Parameter Description
Parameter |
Type |
Description |
event_id |
String |
Event ID. |
timestamp |
Int64 |
Timestamp when the event occurred. |
twin |
Object |
A set of updated device twins. Each twin is in the key-value pair format. The value contains the option flag, the twin metadata contains the value type, the expected status contains the expected value and update time, and the actual status contains the actual value and update time. |
delta |
Map |
Names of twin properties whose actual values are different from expected values, and expected values of these properties. |
Example
When an end device is bound to an edge node, the following message is received:
$hw/events/device/{device_id}/twin/update/delta { "event_id":"b9625811-f34f-4252-bee9-98185e7e1ec7", "timestamp":1557314742131, "twin":{ "state":{ "expected":{ "value":"running", "metadata":{ "timestamp":1557314742122 } }, "optional":true, "metadata":{ "type":"string" } } }, "delta":{ "state":"running" } }
