Device Twin Update
This topic is used to subscribe to device twin updates. It reflects the differences before and after a device twin update.
Topic
$hw/events/device/{device_id}/twin/update/document
Parameter |
Type |
Description |
device_id |
String |
End device ID. |
Usage
Use an MQTT client to subscribe to this topic.
Parameter Description
Parameter |
Type |
Description |
event_id |
String |
Event ID. |
timestamp |
Int64 |
Timestamp when the event occurred. |
twin |
Object |
A set of updated device twins. Each twin is in the key-value pair format. The value contains last (twin information before the update) and last (twin information after the update). The twin information contains the option flag, the twin metadata contains the value type, the expected status contains the expected value and update time, and the actual status contains the actual value and update time. |
Example
When an end device is bound to an edge node, the following message is received:
"event_id":"",
"timestamp":1557314742122,
"twin":{
"state":{
"last":null,
"current":{
"expected":{
"value":"running",
"metadata":{
"optional":true,
"metadata":{
"type":"string"
