Updated on 2025-11-18 GMT+08:00
ConfigMaps
ConfigMaps store configuration details required for workloads. ConfigMaps decouple configuration files from container images to enhance workload portability.
ConfigMaps allow you to:
  • Manage configurations for different environments and services.
  • Deploy workloads in different environments. Multiple versions are supported for configuration files so that you can update and roll back workloads easily.
  • Quickly import configurations in the form of files to containers.
Creating a ConfigMap
  1. Log in to the IEF console.
  2. In the navigation pane, choose Edge Applications > Application Configuration. Then, click Create ConfigMap in the upper right corner.
  3. Specify the ConfigMap details.
    Figure 1 Creating a ConfigMap
    • Name: Enter a ConfigMap name.
    • Data: The configuration data is key-value pairs. Enter a property name and value.
  4. Click Create. After the ConfigMap is created, the ConfigMap list page is displayed.
Using a ConfigMap
You can use ConfigMaps to configure data storage in the advanced settings when creating a containerized application.
Figure 2 Using a ConfigMap
After the ConfigMap is mounted to the container, files are created in the mount directory based on the ConfigMap content. Each property name and value pair is generated as a file. The property name is the file name, and the value is the content of the file. For instance, a ConfigMap could have the property name set to key and the property value set to value. After the ConfigMap is mounted to the /tmp0 directory, a file named key is generated in the /tmp0 directory and the file content is value.
