Configuring Message Notifications
You can configure message notifications for analyzers to receive reports via the configured message receiving method. There are multiple types of analyzers that provide results for external access, best practice compliance and unused access.
Turn off message notifications if you do not want the analysis results. This stops all notifications for access analysis outcomes.
Notes and Constraints
To configure SMN topic notifications, go to the SMN console, create a topic, add a subscription, and configure the notification mode.
- Log in to the new IAM console.
- In the navigation pane of the IAM console, choose Access Analyzer > Notifications, and click Create Notification in the upper right corner of the displayed page.
Figure 1 Creating notifications
- Select the analyzer for which you want to configure notifications.
Figure 2 Selecting an analyzer
- Configure a system notification.
Enabled: The system sends notifications about analysis to the console. You can find them in the messages in the upper right corner of the console.
Disabled: The system does not send notifications about analysis to the console.
- Configure an SMN topic.
Enable: The system sends access analysis through the message notification method you configured in SMN, such as email and mobile number.
Disabled: The system does not send notifications about access analysis changes to SMN.
- Click OK. The system will send access analysis though the notification method you set up.
