Updated on 2025-11-07 GMT+08:00
Deleting an Access Analyzer
You can delete an analyzer if you do not need it anymore.
  • There is at least one access analyzer in the current account.
  • The analyzer status is active, disabled, or failed.
  1. Log in to the new IAM console.
  2. In the navigation pane, choose Access Analyzer > Analyzers Settings.
  3. Locate the target analyzer and click Delete in the Operation column.
  4. In the displayed dialog box, enter DELETE and click OK.
    The deletion operation cannot be undone.
    Figure 1 Deleting an analyzer
