Using URNs to Identify Huawei Cloud Resources
Definition
A uniform resource name (URN) is the unique identifier of a cloud service resource. When you need to specify a resource on Huawei Cloud, for example, in an identity policy or API call, you are required to use the resource URN. You should use and share URNs with caution, but not consider them as confidential information.
URN Format
<service-name>:<region>:<account-id>:<type-name>:<resource-path>
- service-name: the abbreviation of a cloud service name, for example, ecs.
- region: the region where the resource is located, for example, cn-north-1. For a global service, the region can be an asterisk (*) or left blank.
- account-id: the account ID of a tenant. For a public resource, for example, a system identity policy, use system as its account ID.
- type-name: the resource type. For example, enter instance for an ECS.
- resource-path: the resource path, which may be the resource name, ID, or path, which depends on the cloud service. The resource path may contain colons (:).
Example URN
IAM user
iam::{account_id}:user:{user_name}
User group
iam::{account_id}:group:{group_name}
Agency or trust agency
iam::{account_id}:agency:{agency_name}
Service-linked agency
iam::{account_id}:agency:service-linked-agency/{service_principal}/{agency_name}
Custom identity policy
iam::{account_id}:policy:{policy_name}
System-defined identity policy
iam::system:policy:{XXXPolicy}
Assumed-agency/trust agency session
sts::{account_id}::assumed-agency:{agency_name}/{agency_session_name}
SAML identity provider
iam::{account_id}:samlProvider:{provider_name}
OIDC identity provider
iam::{account_id}:oidcProvider:{provider_name}
- agency_session_name in the URN of the assumed-agency/trust agency session obtained through POST /v5/agencies/assume is the value of agency_session_name in the request body of this interface.
- agency_session_name in the URN of the assumed-agency session obtained through POST /v3.0/OS-CREDENTIAL/securitytokens is fixed to null.
- agency_session_name in the URN of the session after an agency or trust agency is switched on the console is fixed to null.
URN Format of a Specific Resource
The URN format varies depending on the cloud service and resource type. Some URNs can contain paths, variables, or wildcards. For the URN format of a specific resource, see Actions Supported by Identity Policy-based Authorization. Then, open the chapter of the specified cloud service and navigate to the "Resource Types" section.
Using Resource Path Wildcards in Identity Policies
You can use the wildcard (*) in the Resource element of an identity policy to match URNs. For more information, see JSON Element Reference. The following are two examples:
"Version": "5.0",
"Statement": [{
"Effect": "Allow",
"Action": [
"iam:agencies:listV5"
"Resource": [
"iam:*:8c1eef3a241945f69c3d3a6b0252e783:agency:*"
"Version": "5.0",
"Statement": [{
"Effect": "Allow",
"Action": [
"sts:agencies:assume"
"Resource": [
"iam:*:*:agency:*"
} What is your overall rating for this page?
