Updated on 2025-11-07 GMT+08:00
Monitoring Temporary Security Credentials
Huawei Cloud records call logs of all operations in CTS, allowing account administrators to trace activities. When configuring a trust agency, the administrator can require to pass a custom string to identify the person or application that performs operations on Huawei Cloud. This string is stored as the source identity information in CTS. When viewing activities in CTS, the administrator can determine who assumed the trust agency to perform operations based on the source identity information.
After the source identity information is set, it is included in any Huawei Cloud operation request processed during the assumed-trust agency session. If you use the AssumeAgency API to assume another trust agency in an agency chain, the source identity information will be passed from one to another and cannot be changed. Administrators can configure identity policies based on whether there is source identity information and its value to control Huawei Cloud operations allowed for trust agencies. You can determine whether to use the source identity information and what it can be.
Permissions Required for Setting Source Identity Information
To set source identity information, your policy must contain the following action in addition to the sts:agencies:assume permission that matches the AssumeAgency API:
sts::setSourceIdentity
  • To specify source identity information for an IAM user to assume a trust agency, the identity policy of the IAM user and the trust policy of the trust agency must have the sts::setSourceIdentity permission.
  • To specify source identity information for an agency to assume another agency, the identity policy of the agency initiating the assumption and the trust policy of the target agency must have the sts::setSourceIdentity permission.
As an account administrator, you may want to allow IAM user A to assume TrustAgencyA in the same in the account only if the source identity is the IAM username. You can attach the following identity policy to the IAM user:
	"Version": "5.0",
	"Statement": [{
		"Effect": "Allow",
		"Action": [
			"sts:agencies:assume",
			"sts::setSourceIdentity"
		"Condition": {
			"StringEquals": {
				"sts:SourceIdentity": [
					"${g:UserName}"
To require that the source principal information must be passed during trust agency assuming, add a trust policy when creating trust agency A. For example, you can configure a trust policy to allow trust agency assuming only when IAM user A passes its username as the source principal information.
	"Version": "5.0",
	"Statement": [{
		"Effect": "Allow",
		"Action": [
		"Condition": {
			"StringEquals": {
					"${g:UserName}"
For details about the source identity information passed when you call the AssumeAgency API, see the source_identity description in Obtaining Temporary Security Credentials Through an Agency or Trust Agency.
Viewing Source Identity Information in CTS
If IAM user A uses the new assumed-trust agency session to perform operations on Huawei Cloud, you will find the source_identity information in the user field of CTS logs recording these operations.
	"api_version": "v5",
	"code": "204",
	"account_id": "xxxxxx",
	"event_type": "global",
	"message": "xxxxxx",
	"operation_id": "DeleteUserV5",
	"project_id": "xxxxxx",
	"read_only": false,
	"request_id": "xxxxxx",
	"resource_account_id": "xxxxxx",
	"resource_id": "xxxxxx",
	"resource_name": "xxxxxx",
	"resource_type": "user",
	"service_type": "IAM",
	"source_ip": "xxx.xxx.xxx.xxx",
	"trace_id": "xxxxxx",
	"trace_name": "deleteUserV5",
	"trace_rating": "normal",
	"trace_type": "ApiCall",
	"tracker_name": "system",
	"user_agent": "xxxxxx",
	"is_consistent": true,
	"user": {
		"access_key_id": "xxxxxx",
		"domain": {
			"id": "xxxxxx",
			"name": "xxxxxx"
		"name": "xxxxxx/test",
		"principal_id": "xxxxxx:name",
		"principal_urn": "sts::xxxxxx:assumed-agency:test/name",
		"session_context": {
			"assumed_by": {
				"principal_id": "xxxxxx"
			"attributes": {
				"created_at": "xxxxxx",
				"mfa_authenticated": "false"
			"source_identity": "IAM User A"
		"type": "AssumedAgency"
	"response": "null",
	"time": xxxxxx,
	"record_time": xxxxxx
