Disabling Server WTP
This section describes how to disable server WTP.
- Log in to the HSS console.
- Click
in the upper left corner and select a region or project. - In the navigation pane, choose .
- Click Server WTP, and click the Servers tab.
- In the Operation column of a server, click Disable Protection.
You can also select all servers and click Disable Protection above the asset list.
If you disable protection, all the functions provided by HSS WTP will be disabled. Exercise caution when performing this operation.
