Deleting Assets Protected by Server WTP
If you have disabled Server WTP for some servers (by referring to Disabling HSS) and do not plan to enable Server WTP for them again, you can delete the information about these servers, so that it will not affect your future O&M. You can delete the information about the asset. Once deleted, all the web tamper protection policies configured for the server will be cleared.
- Log in to the HSS console.
- Click
in the upper left corner and select a region or project. - In the navigation pane, choose . Figure 1 Web tamper protection
- Click Server WTP, and click the Servers tab.
- Locate the target server whose Protection Status is Unprotected.
- In the Operation column of a server, choose . The Delete WTP Configuration dialog box is displayed.
- Confirm the server information to be deleted.
- Enter DELETE in the text box and click OK.
If the server is not displayed in the protected server list, it has been deleted.
