Updated on 2025-09-29 GMT+08:00
Exporting CI/CD Image Scan Results
Export image scan results to a local PC.
Exporting CI/CD Image Scan Results from the Risk View
  1. Log in to the HSS console.
  2. Click in the upper left corner and select a region or project.
  3. In the navigation pane on the left, choose Risk Management > Container Images.
  4. On the Risk View tab page, click a risk sub-tab, and select CI/CD Images from the drop-down list. Click Export.
    Figure 1 Exporting CI/CD image scan results
  5. In the displayed dialog box, click OK.
  6. Wait until an export success message is displayed on the top of the Container Images page. Find the exported file in the default download path on your local PC.
    Do not close the browser page during the export, or the export will be interrupted.
Exporting CI/CD Image Scan Results from the Image View
  4. On the Image View tab page, select CI/CD Images, click Export, and choose a risk type.
    Figure 2 Exporting scan results
