Agent Release Notes
Updated on 2025-01-07 GMT+08:00
HSS will be continuously optimized to improve service capabilities, including but not limited to adding functions and fixing defects. This document describes the updates in each version of the HSS agent.
Agent release notes (Linux)
Agent Version
Update Description
3.2.17
  1. Emergency vulnerability scans support the Arm architecture.
  2. Antivirus can scan TXT files in sensitive mode.
  3. The ransomware honeypot module can check honeypot deployment failures.
  4. Agent protection can be degraded. Known issues on the live network have been fixed.
3.2.15
The bugs of the container security edition were fixed. Known issues on the live network were resolved.
3.2.14
Fileless attack detection is supported. Known issues on the live network are resolved.
3.2.13
The agent can be installed using a key or password. The installation and configuration page is optimized. Known issues on the live network are resolved.
3.2.12
  1. The self-protection function is added to prevent malicious programs from stopping the HSS service process and uninstalling the service agent.
  2. Container image scan supports the containerd runtime.
  3. Baseline checks based on the HCE1.1 general security standard is supported.
  4. Apache RocketMQ applications can be identified. Known issues on the live network were resolved.
3.2.11
Fixed the issue that container information occasionally fails to be collected.
3.2.10
  1. Added automatic virus scan and removal.
  2. IPv6 addresses are supported for each function module.
  3. Added the port honeypot function.
  4. Fixed known issues of the honeypot module on the live network.
3.2.9
  1. Added the virus scan and removal function to support quick, full-disk, and custom scan and removal. Static files on disks can be scanned to enhance virus defense capabilities.
  2. Added the antivirus detection function to check the files flushed to disks in real time and identify most known malicious programs.
  3. Added the emergency vulnerability detection function to check for emergency vulnerabilities.
  4. Fixed known issues on the live network.
Agent release notes (Windows)
Agent Version
Update Description
4.0.26
  1. Emergency vulnerability scans are supported.
  3. The ransomware honeypot module can check driver installation failures honeypot deployment failures.
  4. The ransomware intelligence database supports filtering.
  5. Agent protection can be degraded. Known issues on the live network have been fixed.
4.0.25
4.0.24
The agent can be installed through the GUI or script. The installation and configuration GUI was optimized. Known issues on the live network were resolved.
4.0.23
4.0.22
4.0.21
4.0.20
  2. Added the common weak password detection function to check for weak passwords in Windows.
  3. Fixed known issues on the live network.
4.0.19
  1. Added the samples uploading function.
  2. Added the application control (process whitelist) function.
  3. Brute-force attack detection is supported for SQL Servers.
  4. Added the SQL Server baseline check.
