Modifying Cluster Agent Installation Information
You can modify the access information in the following cases:
- In a non-CCE cluster accessed through a private network, the image repository information has been configured and the command has been generated, but the command has not been executed on cluster nodes. In this case, you can refer to this section to go to the access information modification page and perform subsequent operations.
- In a non-CCE cluster accessed through Internet, the access information has been configured and the command has been generated, but the command has not been executed on cluster nodes. In this case, you can refer to this section to go to the access information modification page and perform subsequent operations.
- In a non-CCE cluster accessed through Internet, the specified certificate expiration date is earlier than the final expiration date, but needs to be changed to that date.
- You need to modify the scope of cluster nodes where the agent is to be installed. After the modification, the agent on all cluster nodes will be automatically uninstalled, and then the agent will be reinstalled on specified nodes.
- The container runtime type and sock address need to be modified. After the modification, the agent on all cluster nodes will be automatically uninstalled, and then the agent will be reinstalled on specified nodes.
- Automatic agent upgrade needs to be enabled or disabled.
Modifying Access Information
- Log in to the HSS console.
- Click
in the upper left corner and select a region or project.
- In the navigation pane, choose .
- Click the Cluster tab.
- In the row of a cluster, click Edit Access Information in the Operation column. The Edit Access Information dialog box is displayed.
The following figure uses the access information of a non-CCE cluster (accessed through Internet) as an example.Figure 1 Edit access information
- Modify access information. For details about the parameters that can be modified, see Table 1.
- Click Complete.
If the container runtime type, container runtime sock address, node selection configuration, or tolerance configuration is modified, the agent on all cluster nodes will be automatically uninstalled and then reinstalled. Wait until the agent installation is complete.
