Exporting the Protection Quota List
This section describes how to export the server protection quota list to your local PC. Currently, the container protection quota list cannot be exported.
- Log in to the HSS console.
- Click
in the upper left corner and select a region or project. - In the navigation tree on the left, choose .
- (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
- Click the Quotas tab.
- Above the protection quota list, click to export the server protection quota list.
If you only need to export specified protection quota information, select the target quota and choose .
Figure 1 Exporting all server protection quotas
- View the export status in the upper part of the page. After the export is successful, obtain the exported information from the default file download address on the local host.
Do not close the browser page during the export. Otherwise, the export task will be interrupted.
