Exporting the Container Node List
This section describes how to export the container node list to your local PC.
Exporting the Container Node List to the Local PC
- Log in to the HSS console.
- Click
in the upper left corner and select a region or project. - In the navigation pane, choose . The container management page is displayed.
- (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
- Choose the Container Nodes tab.
- In the upper part of the container list, click Export to export the list.
You can select multiple container nodes and click Export to export their container details in batches.
The information about up to 1,000 container nodes can be exported at a time.
