Updated on 2025-08-26 GMT+08:00
Configuring a Monitoring Alarm Rule
You can configure HSS alarm rules to customize the monitored objects and notification policies, and set parameters such as the alarm rule name, monitored object, threshold, monitoring period, and whether to send notifications. This helps you learn the HSS protection status in a timely manner.
You can use Cloud Eye to monitor HSS metrics and events. This section describes how to create alarm rules for monitoring metrics and events.
Creating an Alarm Rule for Metric Monitoring
  2. Click in the upper left corner and select a region or project.
  3. Hover your mouse over in the upper left corner of the page and choose Management & Governance > Cloud Eye.
  4. In the navigation pane on the left, choose Alarm Management > Alarm Rule.
  5. In the upper right corner of the page, click Create Alarm Rule.
  6. Enter the alarm rule information as prompted. For more information, see Table 1.
    Figure 1 Alarm rule for metric monitoring
    Table 1 Parameters for creating an alarm rule for metric monitoring
    Example Value
    Name
    Alarm rule name. The system generates a random name, and you can change it if needed.
    alarm-hss
    Alarm rule description. This parameter is optional.
    Alarm Type
    Type of the alarm rule. The value can be Metric or Event.
    Metric
    Cloud Product
    Select the cloud product you want to monitor. This parameter is available only when you set Alarm Type to Metric.
    In the drop-down list, select Host Security Service - Host Security or Host Security Service - Server.
    • Host Security Service - Host Security: The monitoring metrics of an enterprise project, including Total Servers, Unprotected Servers, Unsafe Servers, and Servers Without Agent Running.
    • Host Security Service - Server: The monitoring metrics of servers, including Protection Status and Agent Status.
    Resource Level
    Resource level of the monitored object.
    The resource level of the alarm rule. This parameter is available only when you set Alarm Type to Metric. You can select Cloud product or Specific dimension. Cloud product is recommended.
    Cloud product
    Monitoring Scope
    Monitoring scope the alarm rule applies to.
    • All resources: An alarm will be triggered if a resource of the current cloud product meets the alarm policy. To exclude resources that do not need to be monitored, click Select Resources to Exclude.
    • Resource groups: An alarm will be triggered if any resource in the resource group meets the alarm policy. To exclude resources that do not need to be monitored, click Select Resources to Exclude.
    • If you select Specific resources, click Select Specific Resources and select resources.
    All resources
    Method
    Select Associate template or Configure manually.
    After an associated template is modified, the policies contained in this alarm rule to be created will be modified accordingly.
    Configure manually
    Alarm Policy
    Set this parameter if Method is set to Configure manually.
    For details about how to create a custom template, see Creating a Custom Template.
    Alarm Notifications
    Set whether to send notifications when alarms are triggered. Notifications can be sent by email, text message, or HTTP/HTTPS message.
    Enabled
    Notified By
    Set the method and recipients of alarm notifications.
    Notification policies
  7. Click Create. In the displayed dialog box, click OK.
Creating an Alarm Rule for Event Monitoring
  6. Enter the alarm rule information as prompted. For more information, see Table 2.
    Figure 2 Alarm rule for event monitoring
    Table 2 Parameters for creating an event rule for metric monitoring
    Example Value
    Name
    alarm-hss
    Alarm Type
    Event
    Event Type
    Set this parameter if Alarm Type is set to Event. You can select System event or Custom event.
    Event Source
    • If Event Type is set to System event, select the cloud service that generates the event from the drop-down list.
    • If Event Type is set to Custom event, the event source must be the same as the reported field and written in the <Service>.<Item> format.
    System event
    Method
    Configure manually
    Alarm Policy
    Alarm Notifications
    Enabled
    Notified By
