Viewing Container Information
You can view container information on the Containers page to learn about the container status, cluster, and risks. This section describes how to view container information.
Only the HSS container edition supports this function. For details about how to purchase and upgrade HSS, see Purchasing an HSS Quota and Upgrading Your Edition.
- Log in to the HSS console.
- Click
in the upper left corner and select a region or project. - In the navigation pane, choose . The container management page is displayed.
- (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
- Click the Containers tab. The container page is displayed.
- View the container information and security status. In the container list, you can view the name, status, risks, restart times, pod, cluster type, and cluster for each container.
- View container details.
Click the name of the target container. On the container details page that is displayed, view the container image, process, port, and mount path information.
- View the container risk distribution.
View the number of low-risk, medium-risk, high-risk, and critical risks in the container.
- Export the container list.
Click Export in the upper left corner of the list to export the container list to the local PC.
