Viewing Vulnerability Handling History
For vulnerabilities that have been handled, you can refer to this section to view the vulnerability handling history (handler and handling time).
- The basic edition does not support this function. For details about how to buy and upgrade HSS, see Purchasing HSS and Upgrading a Protection Quota.
- Handling history can be retained for a maximum of 180 days.
Viewing the Handling History of a Vulnerability
- Log in to the HSS console.
- Click
in the upper left corner and select a region or project. - In the navigation pane, choose Risk Management > Vulnerabilities.
- In the list of handled vulnerabilities, click a vulnerability name. The vulnerability details slide-out panel is displayed. Figure 1 Selecting Handled from the drop-down list
- Click the Handling History tab to view the handling history of the vulnerability. Figure 2 Handling history
Viewing the Handling History of All Vulnerabilities
- Click
in the upper left corner and select a region or project. - In the navigation pane on the left, choose . The Handling History page is displayed.
- On the Vulnerabilities tab page displayed, view the handling history of all vulnerabilities.
- Viewing the vulnerability handling history of a specified enterprise project
In the upper left corner of the Handling History page, select an enterprise project for Enterprise Project to view the handling history of server vulnerabilities in the enterprise project.
- Viewing the vulnerability handling history of a specified property
In the search box above the vulnerability handling history list, select an attribute or enter a keyword to search for the handling records of a specified attribute.
