- What's New
- Function Overview
- Product Bulletin
- Technology Poster
- Billing
- Getting Started
User Guide
- Using IAM to Grant Access to HSS
- Accessing HSS
- Checking the Dashboard
- Asset Management
- Risk Management
- Server Protection
Container Protection
Container Firewalls
- Container Firewall Overview
- Configuring a Network Defense Policy (for a Cluster Using the Container Tunnel Network Model)
- Configuring a Network Defense Policy (for a Cluster Using the VPC Tunnel Network Model)
- Configuring a Network Defense Policy (for a Cluster Using the Cloud Native Network 2.0 Model)
- Container Cluster Protection
Container Firewalls
- Detection and Response
- Security Operations
- Installation and Configuration on Servers
- Installation and Configuration on Containers
- Account Management
- Plug-in Settings
- Authorization
- Monitoring and Auditing
- Enterprise Project Management
Best Practices
- HSS Best Practices You May Need
Suggestions on How to Fix Official Disclosed Vulnerabilities Provided by HSS
- Git Credential Disclosure Vulnerability (CVE-2020-5260)
- SaltStack Remote Command Execution Vulnerabilities (CVE-2020-11651 and CVE-2020-11652)
- OpenSSL High-risk Vulnerability (CVE-2020-1967)
- Adobe Font Manager Library Remote Code Execution Vulnerability (CVE-2020-1020/CVE-2020-0938)
- Windows Kernel Elevation of Privilege Vulnerability (CVE-2020-1027)
- Windows CryptoAPI Spoofing Vulnerability (CVE-2020-0601)
- Third-Party Servers Accessing HSS Through a Direct Connect and Proxy Servers
- Connecting Third-Party Servers to HSS Through Direct Connect and VPC Endpoint
- Installing the HSS Agent Using CBH
- Using HSS to Improve Server Login Security
- Using HSS and CBR to Defend Against Ransomware
- Using HSS to Scan and Fix Vulnerabilities
- Using HSS to Prevent Weak Passwords
- Using HSS to Scan for Trojans
- Using HSS to Handle Mining Attacks
- Using HSS to Monitor the Integrity of Linux Server Files
- Whitelist Can Be Used to Avoid False Alarm Reporting
API Reference
- Before You Start
- Calling APIs
API Description
Asset Management
- Collecting Asset Statistics, Including Accounts, Ports, and Processes
- Querying the Account List
- Querying Open Port Statistics
- Querying the Process List
- Querying the Software List
- Querying Automatic Startup Item Information
- Querying the Server List of an Account
- Querying the Open Port List of a Single Server
- Querying the Server List of the Software
- Querying the Service List of Auto-Started Items
- Obtaining the Account Change History
- Obtaining the Historical Change Records of Software Information
- Obtaining the Historical Change Records of Auto-started Items
- Asset Fingerprints - Process - Server List
- Asset Fingerprints - Port - Server List
- Querying the Middleware List
- Querying the Server List of a Specified Middleware
Ransomware Prevention
- Querying the Servers Protected Against Ransomware
- Querying the Protection Policy List of Ransomware
- Modifying Ransomware Protection Policies
- Enabling Ransomware Prevention
- Disabling Ransomware Prevention
- Querying the Backup Policy Bound to HSS Protection Vault
- Modifying the Backup Policy Bound to Vault
Baseline Management
- Querying the Weak Password Detection Result List
- Querying the Password Complexity Policy Detection Report
- Querying the Result List of Server Security Configuration Check
- Querying the Check Result of a Security Configuration Item
- Querying the Checklist of a Security Configuration Item
- Querying the List of Affected Servers of a Security Configuration Item
- Querying the Report of a Check Item in a Security Configuration Check
- Ignoring, Unignoring, Repairing, or Verifying the Failed Configuration Check Items
- Quota Management
- Container Management
- Event Management
- Intrusion Detection
- Server Management
Container Image
- Querying the Image List in the SWR Image Repository
- Scanning Images in the Image Repository in Batches
- Querying the Local Image List
- Querying Image Vulnerability Information
- CVE Information Corresponding to the Vulnerability
- Synchronizing the Image List from SWR
- Querying the List of Image Security Configuration Detection Results
- Querying the Check Item List of a Specified Security Configuration Item of an Image
- Querying the Mirror Configuration Check Report
- Policy Management
Vulnerability Management
- Querying the Vulnerability List
- Exporting Information About Vulnerabilities and Their Affected Servers
- Querying the Servers Affected by a Vulnerability
- Changing the Status of a Vulnerability
- Querying Vulnerability Information About a Server
- Creating a Vulnerability Scan Task
- Querying a Vulnerability Scan Policy
- Modifying a Vulnerability Scan Policy
- Querying the Vulnerability Scan Tasks
- Querying the List of Servers Corresponding to a Vulnerability Scan Task
- Querying Vulnerability Management Statistics
- Web Tamper Protection
- Tag Management
- Cluster Management
Asset Management
- Appendixes
- SDK Reference
About HSS
- What Is Host Security?
- What Is Container Security?
- What Is Web Tamper Protection?
- What Are the Relationships Between Images, Containers, and Applications?
- How Do I Use HSS?
- Can HSS Protect Local IDC Servers?
- Is HSS in Conflict with Any Other Security Software?
- What Are the Differences Between HSS and WAF?
- Can HSS Be Used Across Accounts?
- What Is the HSS Agent?
- Can HSS Be Used Across Clouds?
- Does HSS Support Version Upgrade?
- Can HSS Automatically Detect and Remove Viruses?
Agent
- Do I Need to Install the HSS Agent After Purchasing HSS?
- Is the Agent in Conflict with Any Other Security Software?
- How Do I Uninstall the Agent?
- What Should I Do If Agent Installation Failed?
- How Do I Fix an Abnormal Agent?
- What Is the Default Agent Installation Path?
- How Many CPU and Memory Resources Are Occupied by the Agent When It Performs Scans?
- Do Different HSS Editions Share the Same Agent?
- How Do I View Servers Where No Agents Have Been Installed?
- How Do I Upgrade the Agent?
- What Do I Do If the HSS Upgrade Fails?
- What Resources Will Be Accessed by the Agent After It Is Installed on a Server?
- How Do I Use Images to Install Agents in Batches?
- What Do I Do If I Cannot Access the Download Link of the Windows Or Linux Agent?
- What Do I Do If Agent Upgrade Fails and the Message "File replacement failed" Is Displayed?
- What Can I Do If Agents Failed to Be Installed in Batches and a Message Is Displayed Indicating that the Network Is Disconnected?
- How Do I Verify the Connection Between My Server and the HSS Server?
- Protection
- How Do I Fix Vulnerabilities?
- What Do I Do If an Alarm Still Exists After I Fixed a Vulnerability?
- Why a Server Displayed in Vulnerability Information Does Not Exist?
- Do I Need to Restart a Server After Its Vulnerabilities Are Fixed?
- Can I Check the Vulnerability and Baseline Fix History on HSS?
- What Do I Do If Vulnerability Fix Failed?
- Why Can't I Select a Server During Manual Vulnerability Scanning or Batch Vulnerability Fixing?
- What Do I Do If a Vulnerability Scan Failed?
- Do I Need to Subscribe to Ubuntu Pro to Fix Ubuntu Vulnerabilities?
Detection & Response
- How Do I View and Handle HSS Alarm Notifications?
- What Do I Do If My Servers Are Subjected to a Mining Attack?
- Why a Process Is Still Isolated After It Was Whitelisted?
- Why an Attack Is Not Detected by HSS?
- Can I Unblock an IP Address Blocked by HSS, and How?
- Why a Blocked IP Address Is Automatically Unblocked?
- How Often Is Malware Scan and Removal?
- How Often Are the HSS Virus Database and Vulnerability Database Updated?
- What Do I Do If an IP Address Is Blocked by HSS?
- How Do I Defend Against Ransomware Attacks?
- Why Can't I Receive Alarms After the HSS Is Upgraded?
- How Do I Add High-risk Command Execution Alarms to the Whitelist?
- Why Doesn't HSS Generate Alarms for Some Web Shell Files?
- Abnormal Logins
Brute-force Attack Defense
- How Does HSS Intercept Brute Force Attacks?
- How Do I Handle a Brute-force Attack Alarm?
- How Do I Defend Against Brute-force Attacks?
- How Do I Unblock an IP Address?
- What Do I Do If HSS Frequently Reports Brute-force Alarms?
- What Do I Do If a Huawei Cloud IP Address Trigger a Brute-force Attack Alarm?
- What Do I Do If the Port in Brute-force Attack Records Is Not Updated?
Baseline Inspection
- Why Are Weak Password Alarms Generated After the Weak Password Detection Policy Is Disabled?
- How Do I Install a PAM and Set a Proper Password Complexity Policy in a Linux OS?
- How Do I Set a Proper Password Complexity Policy in a Windows OS?
- How Do I Handle Unsafe Configurations?
- How Do I View Configuration Check Reports?
- How Do I Handle a Weak Password Alarm?
- How Do I Set a Secure Password?
- Why Do I Need to Add a Protected Directory?
- How Do I Modify a Protected Directory?
- What Should I Do If WTP Cannot Be Enabled?
- How Do I Modify a File After WTP Is Enabled?
- What Can I Do If I Enabled Dynamic WTP But Its Status Is Enabled but not in effect?
- What Are the Differences Between the Web Tamper Protection Functions of HSS and WAF?
Container Security
- How Do I Disable Node Protection?
- How Do I Switch from CGS to HSS?
- How Do I Enable Node Protection?
- How Do I Enable the API Server Audit for an On-Premises Kubernetes Container?
- What Do I Do If the Container Cluster Protection Plug-in Fails to Be Uninstalled?
- What Do I Do If the Cluster Connection Component (ANP-Agent) Failed to Be Deployed?
- What Do I Do If Cluster Permissions Are Abnormal?
- Failed to Upload the Image to the Private Image Repository
- What Do I Do If I Failed to Enable Protection for a CCE Cluster?
- Ransomware Prevention
- Region and AZ
Security Configurations
- How Do I Clear the SSH Login IP Address Whitelist Configured in HSS?
- What Can I Do If I Cannot Remotely Log In to a Server via SSH?
- How Do I Use 2FA?
- What Do I Do If I Cannot Enable 2FA?
- Why Can't I Receive a Verification Code After 2FA Is Enabled?
- Why Does My Login Fail After I Enable 2FA?
- How Do I Add a Mobile Number or Email Address for 2FA?
- Do I Use a Fixed Verification Code for 2FA?
- Will I Be Billed for Alarm Notifications and SMS?
- How Do I Modify Alarm Notification Recipients?
- Why No Topics Are Available for Me to Choose When I Configure Alarm Notifications?
- Can I Disable HSS Alarm Notifications?
- How Do I Modify Alarm Notification Items?
- How Do I Disable the SELinux Firewall?
Protection Quota
- How Do I Extend the Validity Period of HSS Quotas?
- How Do I Filter Unprotected Servers?
- Why Can't I Find the Servers I Purchased on the Console?
- What Do I Do If My Quotas Are Insufficient and I Failed to Enable Protection?
- How Do I Allocate My Quota?
- If I Change the OS of a Protected Server, Does It Affect My HSS Quota?
- Why Doesn't an HSS Edition Take Effect After Purchase?
- How Do I Change the Protection Quota Edition Bound to a Server?
- Can I Bind a Server to an HSS Quota If They Are in Different Enterprise Projects?
- Billing, Renewal, and Unsubscription
- How Do I Use the Windows Remote Desktop Connection Tool to Connect to a Windows Server?
- How Do I Check HSS Log Files?
- How Do I Enable Logging for Login Failures?
- How Do I Clear an Alarm on Critical File Changes?
- Why Can't I View All Projects in the Enterprise Project Drop-down List?
- How Do I Enable or Disable HSS Self-protection?
- What Do I Do If Windows Self-Protection Cannot Be Disabled?
- Why Is a Deleted ECS Still Displayed in the HSS Server List?
About HSS
- Videos
More Documents
User Guide (Ankara Region)
- Introduction
- Enabling HSS
- Server Security Dashboard
- Asset Management
- Risk Prevention
- Prevention
- Security Report
- Installation & Configuration
- Permissions Management
About HSS
- What Is HSS?
- What Is Container Security Service?
- How Do I Use HSS?
Agent FAQs
- How Do I Install the Agent?
- Do WTP and HSS Use the Same Agent?
- How Do I Do If the Account Cracking Prevention Function Does Not Take Effect on Some Linux Accounts?
- What Do I Do If My Remote Server Port Is Not Updated in Brute-force Attack Records?
- Weak Passwords and Unsafe Accounts
Intrusions
- What Do I Do If a Mining Process Is Detected on a Server?
- Why Some Attacks on Servers Are Not Detected?
- How Often Does HSS Detect, Isolate, and Kill Malicious Programs?
- Abnormal Logins
- Unsafe Settings
- Vulnerability Management
- Container Guard Service
- Ransomware Protection
- How Do I Use 2FA?
- How Do I Add a Mobile Phone Number or Email Address for Receiving 2FA Verification Notifications?
- If I Choose to Use Verification Code for 2FA, How Do I Get the Code?
- Quotas
- How Do I Use the Windows Remote Desktop Connection Tool to Connect to a Server?
- Is HSS Available as Offline Software?
- How Do I Enable HSS Self-Protection?
- What Do I Do If HSS Self-Protection Cannot Be Disabled?
About HSS
- Change History
- Introduction
- Enabling HSS
- Asset Management
- Risk Prevention
Prevention
- Application Protection
- WTP
- File Integrity Monitoring
Container Firewalls
- Creating a Policy (for a Cluster Using the Container Tunnel Network Model)
- Creating a Policy (for a Cluster Using the VPC Network Model)
- Managing Policies (for a Cluster Using the Container Tunnel Network Model)
- Managing Policies (for a Cluster Using the VPC Network Model)
- Security Report
- Audit
- Manually Upgrading HSS
- About HSS
Agent FAQs
- What Can I Do If the Agent Status Is Still "Not installed" After Installation?
- What Do I Do If the Account Cracking Prevention Function Does Not Take Effect on Some Accounts for Linux Servers?
Intrusions
- Abnormal Logins
- Unsafe Settings
- How Do I Use 2FA?
- Others
- Change History
User Guide (Paris)
- Introduction
- Enabling HSS
Asset Management
- Asset Management
- Server Fingerprints
- Container Fingerprints
- Server Management
- Risk Prevention
Prevention
- WTP
Container Firewalls
- Security Report
- Audit
- About HSS
Agent FAQs
- What Addresses Do ECSs Access After the Agent Is Installed?
Intrusions
- Abnormal Logins
- Unsafe Settings
- Do I Need to Restart a Server After Fixing its Vulnerabilities?
- How Do I Use 2FA?
- Change History
You can configure network defense policies to limit the access traffic to the pods in a cluster using the container tunnel network model. If no network policies are configured, all the inbound and outbound traffic of the pods in a namespace are allowed by default.
This section describes how to configure a network policy for a cluster using the container tunnel network model.
- Only clusters that use the tunnel network model support network policies. Network policies are classified into the following types:
- Inbound rules, which are supported by all cluster versions.
- Outbound rules, which are supported only by clusters in version 1.23 and later.
- Network isolation is not supported for IPv6 addresses.
Creating a Network Defense Policy
You can create a network defense policy in various ways.
- In the upper left corner of the page, select a region, click
, and choose Security & Compliance > HSS.
- In the navigation pane on the left, choose Container Protection > Container Firewalls.
- (Optional) If you have enabled the enterprise project, select the enterprise project where the target server resides from the drop-down list.
- Click Synchronize above the cluster list to synchronize the policies created on clusters.
The synchronization takes about 1 to 2 minutes. Wait for a while and click
in the upper right corner of the list to refresh and view the latest data.
Figure 1 Synchronizing CCE Cluster policies - Click Manage Policy in the Operation column of a cluster using the container tunnel network model.
- Click Create from YAML above the policy list.
- On the YAML creation page, enter content or click Import.
An example of a network policy created from YAML is as follows:
apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: test-network-policy namespace: default spec: podSelector: # The rule takes effect for pods with the role=db label. matchLabels: role: db policyTypes: - Ingress - Egress ingress: # Ingress rule - from: - namespaceSelector: # Only namespaces with project=myproject can be accessed. matchLabels: project: myproject - podSelector: # Only the traffic from the pods with the role=frontend label is allowed. matchLabels: role: frontend ports # Only TCP can be used to access port 6379. - protocol: TCP port: 6379 egress: # Egress rule - to: - ipBlock: #Only the 10.0.0.0/24 network segment of the destination object can be accessed. cidr: 10.0.0.0/24 ports: # Only TCP can be used to access port 6379 of the destination object. - protocol: TCP port: 6379
- Click OK.
Figure 2 Synchronizing CCE Cluster policies - Click Manage Policy in the Operation column of a cluster using the container tunnel network model.
- Click Create Network Policy above the network policy list.
- Policy Name: Enter a network policy name.
- Namespace: Select a namespace for the network policy.
- Selector: Enter a key and a value to set the pod to be associated, and click Add. You can also click Reference Workload Label to reference the label of an existing workload. If this parameter is not specified, all pods in the namespace are associated by default.
- Inbound rule: Click Add Rule in the Inbound Rules area. For more information, see Table 1.
Table 1 Adding an inbound rule Parameter
Protocol & Port
Enter the inbound protocol type and port number of the pods to be associated. Currently, TCP and UDP are supported. If this parameter is not specified, all access traffic is allowed.
Source Namespace
Select a namespace whose objects can be accessed. If this parameter is not specified, access to the objects that belong to the same namespace as the current policy is allowed.
Source Pod Label
Select a label. Pods with this label can be accessed. If this parameter is not specified, all pods in the namespace can be accessed.
- Outbound rule: Click Add Rule in the Outbound Rules area. For more information, see Table 2.
Table 2 Adding an outbound rule Parameter
Protocol & Port
Enter the port and protocol of destination objects. If this parameter is not specified, access is not limited.
Destination CIDR Block
Configure CIDR blocks. This parameter allows requests to be routed to a specified CIDR block (and not to the exception CIDR blocks).
Separate the destination and exception CIDR blocks by vertical bars (|), and separate multiple exception CIDR blocks by commas (,).
For example, 172.17.0.0/16|172.17.1.0/24,172.17.2.0/24 indicates that 172.17.0.0/16 is accessible, but not for 172.17.1.0/24 or 172.17.2.0/24.
Destination Namespace
Namespace where the destination object is located. If not specified, the object belongs to the same namespace as the current policy.
Destination Pod Label
- Click OK.
- Click OK.
Protocol & Port
Source Namespace
Source Pod Label
Protocol & Port
- Click OK.
Related Operations
Modifying or deleting a network policy
- Log in to the HSS console.
- Click Synchronize above the network policy list.
- Manage policies as needed.
- Modifying a policy
- In the Operation column of a policy, click Edit YAML. On the YAML page, modify the YAML content and click OK.
- In the Operation column of a policy, click Update. Modify the network policy information and click OK.
- Deleting a policy
- In the Operation column of a policy, click Delete. In the confirmation dialog box, click OK.
- Select one or multiple policies and click Delete above the policy list. In the displayed dialog box, click OK.
