Viewing Plug-in Information
The plug-in configuration page displays the server list and the plug-in information of the servers. If no plug-ins are installed on a server, the corresponding plug-in information is empty. You can view the plug-in information of a server to determine the servers where plug-ins need to be installed.
- Log in to the HSS console.
- Click
in the upper left corner and select a region or project.
- In the navigation pane on the left, choose Installation & Configuration > Plug-in Settings.View plug-in details on the plug-in settings page. For more information, see Table 1.
By default, all servers are displayed in the plug-in list. If a plug-in is installed on a server, the plug-in details are displayed. If no plug-ins are installed on a server, the plug-in information is empty.
Table 1 Docker plug-in list parameters Parameter
Server Name/ID
Server name and ID
IP Address
Server IP address
OS
Type of the OS running on the server
Plug-in Name
Name of the plug-in installed on the server.
Plug-in Version
Plug-in Status
Current status of the plug-in.
- Created: The plug-in has been created but has not been started.
- Running: The plug-in is running properly.
- Paused: The plug-in is paused.
- Restarting: The plug-in is being restarted.
- Removing: The plug-in is being deleted.
- Exited: The plug-in has been stopped.
- Dead: The plug-in cannot be started or has been deleted.
Plug-in Upgrade Status
Plug-in upgrade status.
- Not upgraded: The plug-in has not been upgraded to the latest version.
- Upgrading: The plug-in is being upgraded.
- Upgraded: The plug-in has been upgraded.
- Upgrade failed: The plug-in failed to be upgraded.
